Por último quiero poner el fichero de configuración que me aparece en la herramienta mesact. A ver si alguien me puede decir alguna cosa.
Configuration Name: HOSTMOT2
BoardName : MESA7I95
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 29
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for Step/DIR+Serial+Encoders -> 7I95_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-2,3 0 IOPort StepGen 0 Step/Table1 (Out)
TB3-4,5 1 IOPort StepGen 0 Dir/Table2 (Out)
TB3-8,9 2 IOPort StepGen 1 Step/Table1 (Out)
TB3-10,11 3 IOPort StepGen 1 Dir/Table2 (Out)
TB3-14,15 4 IOPort StepGen 2 Step/Table1 (Out)
TB3-16,17 5 IOPort StepGen 2 Dir/Table2 (Out)
TB3-20,21 6 IOPort StepGen 3 Step/Table1 (Out)
TB3-22,23 7 IOPort StepGen 3 Dir/Table2 (Out)
TB4-2,3 8 IOPort StepGen 4 Step/Table1 (Out)
TB4-4,5 9 IOPort StepGen 4 Dir/Table2 (Out)
TB4-8,9 10 IOPort PWM 0 PWM (Out)
TB4-10,11 11 IOPort PWM 0 Dir (Out)
TB2-14,15 12 IOPort SSerial 0 RXData0 (In)
TB4-16,17 13 IOPort SSerial 0 TXData0 (Out)
Internal 14 IOPort SSerial 0 TXEn0 (Out)
TB4-20,21 15 IOPort SSerial 0 RXData1 (In)
TB4-22,23 16 IOPort SSerial 0 TXData1 (Out)
Internal 17 IOPort SSerial 0 TXEn1 (Out)
TB1-1,2,9,10 18 IOPort MuxedQCount 0 MuxQ-A (In)
TB1-4,5,12,13 19 IOPort MuxedQCount 0 MuxQ-B (In)
TB1-7,8,15,16 20 IOPort MuxedQCount 0 MuxQ-IDX (In)
TB1-17,18 TB2-1,2 21 IOPort MuxedQCount 1 MuxQ-A (In)
TB1-20,21 TB2-4,5 22 IOPort MuxedQCount 1 MuxQ-B (In)
TB1-23,24,TB2-7,8 23 IOPort MuxedQCount 1 MuxQ-IDX (In)
TB2-9,10,17,18 24 IOPort MuxedQCount 2 MuxQ-A (In)
TB2-11,12,20,21 25 IOPort MuxedQCount 2 MuxQ-B (In)
TB2-15,16,23,24 26 IOPort MuxedQCount 2 MuxQ-IDX (In)
Internal 27 IOPort MuxedQCountSel 0 MuxSel0 (Out)
Internal 28 IOPort InMux 0 Addr0 (Out)
IO Connections for I/O+Expansion -> 7I95_1
Internal 29 IOPort InMux 0 Addr1 (Out)
Internal 30 IOPort InMux 0 Addr2 (Out)
Internal 31 IOPort InMux 0 Addr3 (Out)
Internal 32 IOPort InMux 0 Addr4 (Out)
Internal 33 IOPort InMux 0 Data0 (In)
TB3-13,14 34 IOPort SSR 0 Out-00 (Out)
TB3-15,16 35 IOPort SSR 0 Out-01 (Out)
TB3-17,18 36 IOPort SSR 0 Out-02 (Out)
TB3-19,20 37 IOPort SSR 0 Out-03 (Out)
TB3-21,22 38 IOPort SSR 0 Out-04 (Out)
TB3-23,24 39 IOPort SSR 0 Out-05 (Out)
Internal 40 IOPort SSR 0 AC Ref (Out)
P1-01/DB25-01 41 IOPort None
P1-02/DB25-14 42 IOPort None
P1-03/DB25-02 43 IOPort None
P1-04/DB25-15 44 IOPort None
P1-05/DB25-03 45 IOPort None
P1-06/DB25-16 46 IOPort None
P1-07/DB25-04 47 IOPort None
P1-08/DB25-17 48 IOPort None
P1-09/DB25-05 49 IOPort None
P1-11/DB25-06 50 IOPort None
P1-13/DB25-07 51 IOPort None
P1-15/DB25-08 52 IOPort None
P1-17/DB25-09 53 IOPort None
P1-19/DB25-10 54 IOPort None
P1-21/DB25-11 55 IOPort None
P1-23/DB25-12 56 IOPort None
P1-25/DB25-13 57 IOPort None
