Post installation / problème pour ouvrir des images / Paramétrage de Python ?
17 Nov 2025 14:08 #338572 by stephhubert
Bonjour à toutes et tous,
Quand j'ouvre une image en .png, il apparaît ce message :
  File "/usr/bin/image-to-gcode", line 34, in <module>
    plus_inf = numpy.core.Inf
  File "/usr/lib/python3/dist-packages/numpy/core/__init__.py", line 30, in __getattr__
    attr = getattr(_core, attr_name)
  File "/usr/lib/python3/dist-packages/numpy/_core/__init__.py", line 167, in __getattr__
    raise AttributeError(f"Module {__name__!r} has no attribute {name!r}")
AttributeError: Module 'numpy._core' has no attribute 'Inf'. Did you mean: 'inf'?
D'où vient mon problème ?
Quelles perspectives pour corriger ?
Merci !
  • Moderator
  • Moderator
17 Nov 2025 14:35 #338576 by tommylight
Try dmap2gcode from
www.scorchworks.com/Dmap2gcode/dmap2gcode.html
The error seems to be dues to uppercase I letter where there should be a lower case letter i, but it seems to be in the software and might require editing the source code and issuing a pull request on GitHub.
12 Apr 2026 12:37 #345460 by lkt
funny thing, I had same problem, that's why I'm here.
See the output, especially last line:
So, I edited line 34 in /usr/bin/image-to-gcode - changed .Inf --> .inf
It seems to be working :)
Time to create page: 0.097 seconds
