Run/Step Hold/Resume Buttons
7 years 10 months ago #121964 by andypugh
You might also like to look at LUT5, this is a HAL component that can define an output (boolean) for every possible state of 5 inputs. It is good for interlocks and such.
One thing that can make it even more useful is to feed the output back to one of the inputs. Then it can be used as a flip-flop. for example).
In your example you could wire cycle-start, halui.program-is-paused, door interlock, etc into a LUT5 and get a specific output for each combination.
7 years 5 months ago #134127 by phoenix
its not working at all u moron
at least test something before posting
7 years 5 months ago - 7 years 5 months ago #134129 by pl7i92
Replied by pl7i92 on topic Run/Step Hold/Resume Buttons
Mr Bushan
posting in 4 Different treads the same question is not the best behavior
i gave a advice in the tred external start
with clear pinnaming
this workes on all versions of linuxcnc
it is only one line
to be added
Last edit: 7 years 5 months ago by pl7i92.
The following user(s) said Thank You: phoenix
7 years 5 months ago #134131 by phoenix
the all i am asking to you guys is which line and where to add it thats it
i just want start button
7 years 5 months ago - 7 years 5 months ago #134152 by bevins
Replied by bevins on topic Run/Step Hold/Resume Buttons
Bhushan wrote: its not working at all u moron
He told you what to do. You didnt do what he said, then you call him a moron. lol
Do exactly what he said, then open halshow and look at your pin and make sure you are getting your input.
Last edit: 7 years 5 months ago by bevins.
7 years 5 months ago #134153 by phoenix
listen u ###### i dont know how to connect hal pins to signals or components
if u can help just help or just dont do anything
