Basic Pendant with 7i73
9 years 6 months ago #92478 by rodw
Replied by rodw on topic Basic Pendant with 7i73
Thanks, can the 7i73 accept an MPG wheel that only has single sided inputs (+5v, -5v, A+, A-)?
This is how I got a MPG going on a 7i763 using its MPG input. It should get you going with using it.
forum.linuxcnc.org/show-your-stuff/32029...build?start=20#85279
9 years 5 months ago #92505 by rotwang
Replied by rotwang on topic Basic Pendant with 7i73
I'm going to assume you meant (+5v,GND,A+,B+) so yes that's the only sort of encoder that the 7i73 accepts. I guess the logic is that any encoder would be physically close to the 7i73 (in the same enclosure even), and therefore doesn't need differential signaling. Also as it's probably going to be used to adjust values up/down it doesn't need index either.
Roger
7 years 7 months ago #127611 by Peter
Replied by Peter on topic Basic Pendant with 7i73
Hi all.
I'm about to stumble down this path myself and have a couple questions off the top.
I have a Newhaven NHD-0420E2Z-NSW-BBW display which is listed as a 5v display, though it seems the logic on the 7i73 is 3.3v? is that just the GPIO or does that include the display pins as well?
I am currently trying to get through the Hal manual ( having a hard time...) is there a way to directly control an output pin on say a 7i76 from a button press at a 7i73?
Thanks!
more questions to come
7 years 7 months ago #127613 by Mike_Eitel
Replied by Mike_Eitel on topic Basic Pendant with 7i73
I use 7i73 with 5V LCD without problem.
But be aware that quite a lot of such displays make trouble with brightness. Have quite a bunch that expext slightly negative voltage at that pin. So I often have a " helper" circuit with lmc7660.
Mike
7 years 7 months ago #127754 by Peter
Thanks for that. I now have the lcd going on a 7i83
now to get the scales and spindle going...
-Peter
7 years 7 months ago #128138 by pl7i92
Replied by pl7i92 on topic Basic Pendant with 7i73
The Costs are running high on this project
can you give me a "Special NEED " or is it only can it be Done
a Big DRO Display at Atmel component up to 4Inch can be done on mutch lower cost
and as i mangiend earlier a ready made one like hb04 benefits more then the 7i73 with all the work goiing in
Time to create page: 0.264 seconds
