Ejemplo modificado etch servo a 5 ejes
29 Aug 2020 21:58 - 29 Aug 2020 22:11 #179973
by Profed81
Modified example etch servo to 5 axis was created by Profed81
Last edit: 29 Aug 2020 22:11 by Profed81. Reason: I don't speak English
- Thank you received: 5927
29 Aug 2020 22:28 #179979
Replied by tommylight on topic Modified example etch servo to 5 axis
30 Aug 2020 19:16 #180100
by Profed81
Replied by Profed81 on topic Modified example etch servo to 5 axis
I think linux can only handle up to 8 encoder inputs, so what function should I add to the hal code to add a steper motor on the 5th axis?
30 Aug 2020 19:48 #180101
Replied by PCW on topic Modified example etch servo to 5 axis
LinuxCNCs encoder component can handle up to 8 encoders. Why would you need more than 5 encoders? (or possibly 6 if you have a spindle encoder)
30 Aug 2020 19:59 - 30 Aug 2020 20:01 #180102
by Profed81
I mean 8 channels, does that mean 4 servo motors?
Last edit: 30 Aug 2020 20:01 by Profed81.
30 Aug 2020 20:01 #180103
No, that would support up to 8 servo motors with encoder feedback to LinuxCNC
30 Nov 2020 05:49 #190650
by Profed81
It needs to be compile?
Replied by Profed81 on topic Ejemplo modificado etch servo a 5 ejes
Where is that file?Attached you will find a ready made config with 4 axis and a VCP panel that shows everything from PWM output to encoder inputs, just add another axis.
Some editing required, but for 4 axis it works as is and it looks like this:
30 Nov 2020 09:55 #190662
Replied by tommylight on topic Ejemplo modificado etch servo a 5 ejes
It is attached in the above post, no compiling, just unzip and start linuxcnc with the included ini file.
It does use parallel ports.
Time to create page: 0.607 seconds
