Tuning problems
Sorry Harry I missed your post I was having limit issues, but those are resolved and I'm off to new problems as stated above.
![:unsure: :unsure:](/media/kunena/emoticons/unsure.png)
After getting the limits figured and the scale, it's maddening I'm so close to being done..... When I run a program the axis move slow and vibrate and are quite loud! My setup is an X2 mini mill with ballscrew concversion. Keling 4030 drivers and keling C10 breakout board. Drivers set to half stepping and so is AXIS.
Does the machine go to where it is commanded or does it lose steps?When I run a program the axis move slow and vibrate and are quite loud!
On the mdi page is the speed override set lower than 100%
Have you checked the power supply is the proper voltage and amps?
Are the drivers set for the proper amps?
On the MDI if you enter...
F10
G01 X0Y0
G01 X2
G01 Y2
G01 X0Y0
F20
G01 X2
G01 Y2
G01 X0Y0
F30
G01 X2
G01 Y2
G01 X0Y0
Does the machine make the proper moves at speed, end up where it started and sound O.K.?
Most steppers can vibrate at certain low rpms.
Rick G
Great that did it thanks a bunch! OK. now I have a new problem. When I start the program it runs so slow, and it sounds horrible! I had it running great in stepconf. ???????
I know when I ran my system in half stepping with my old software it sounded bad as well
(especially at low speeds), going to quarter stepping does make it sound a lot more pleasant.
But my understanding is as you move from half to quarter
stepping you may loose a little torque on the stepper motors.
Rick Yes it does except at low speed it vibrates a lot. I think I'm gonna try 1/4 stepping n see how that works out. thanks
Harry I think your right
thanks
Thanks to everyone for the help, I'll post an update after I try 1/4 stepping.
SubMicro
A.K.A Robert Willis
I wanted to ask if anyone new how to properly set up the acceleration, ramping, velocity?
SubMicro
Well if your loosing steps your acceleration is too high or voltage too low or binding.
Have you seen the stepper testing section in the Diagnostics chapter of the Integrators manual?
I'll go back and re-RTFM......
SubMicro
Then retest.
At first make your adjustment large say reduce acceleration by 25% see if that helps.
Also reduce velocity you can loose steps by setting the velocity and or the acceleration too high.
The gradually bring the velocity up till you find your best speed, same with acceleration.
When you find the best combination back off from both the acceleration and the velocity to give yourself a margin of error for working in the real world with a load on the machine.
Rick G
Yes I figured some of it was from binding, I'm addressing that issue today! I'm running @ 36v 2.8a. I've read through the manuals, but they seem to me, to be written for someone with alot more experience with this stuff than me!
SubMicro
If you think the manuals are written for an experienced user you should look at the ones we had a few years ago, they were precisely accurate and written in programmer speak. It took me years to translate them from programmer speak to redneck. The g code section is currently getting a make over as it is scattered out a bit...
Yea, 36v won't push much acceleration in a stepper system. My plasma uses 65v to get some good acceleration and speed from my steppers using Gecko 203v drives.
![;) ;)](/media/kunena/emoticons/wink.png)
