Configuring LinuxCNC
Basic Configuration
out of bounds configuration
Thank you received: 0
09 Jan 2012 00:54 #16459
by alexr
Just in case some one else is following this... i am now reading the following
EMC V2.4 Integrator Manual, Chapter 4, 4.3 Homing, page 22
If anything else is to be posted it is no longer " a basic configuration" issue. Once I configure and home my mill properly then my problem is solved.
But as for the initial red bounding box problem it will not be fixed unless your device is correctly homed.
IN SUMMERY
Make sure every detail in stepconf is correct (hey no laughing)
Make sure hardware and software specifications are exactly the same (hardware with programmable features set as default)
and Bless those who try and help you.
Basic Configuration
