is there a way to fake homing of an axis?
- garymcrobertpdx
14 Jan 2012 04:03 #16750
by garymcrobertpdx
is there a way to fake homing of an axis? was created by garymcrobertpdx
I have a 5 axis mill setup at the moment axis A is not completed and therefor not in use.
Axis B rotates the mill head. Axis X, Y, Z and B have homing sensors and work fine.
But I have not yet found a way to get EMC2 ignore that axis A is not homed or fake
a home of A. EMC2 will not operate until A is seen to be homed
Is there some trick to work around this problem?
14 Jan 2012 04:34 #16751
Replied by PCW on topic Re:is there a way to fake homing of an axis?
www.linuxcnc.org/docview/html/config_ini_homing.html
in 0.1.2 Homing Sequence
notice the "none" homing option
when "none" is selected you can just press the home button in Axis
and the selected axis will use its current position as home
- garymcrobertpdx
14 Jan 2012 05:07 - 14 Jan 2012 06:29 #16753
by garymcrobertpdx
Replied by garymcrobertpdx on topic Re:is there a way to fake homing of an axis?
I tried this approach but it failed to make EMC2 ignore the unhomed
A axis and EMC2 refuses to go any further.
I will take another look at the ini file perhaps I messed up a line of code
something that causes a problem but dose not show an error.
Found it! The homing sequence number was not specified I set it
so the A axis would be homed after all the other axis and it now
works.
works.
Last edit: 14 Jan 2012 06:29 by garymcrobertpdx.
Time to create page: 0.098 seconds
