I can runing jog before homing on axis shell
10 Feb 2012 11:26 #17546
by ArcEye
Replied by ArcEye on topic Re:I can runing jog before homing on axis shell
Hi
If you want to hack axis, this works
Replace this section of code
with this
Usual caveats apply, save a copy of axis before editing.
Certainly inhibits jogging until all axes homed on my test set up with both 2.4.6 and 2.5
def jog(*args):
if not manual_ok(): return
ensure_mode(emc.MODE_MANUAL)
c.jog(*args)
# XXX correct for machines with more than six axes
jog_after = [None] * 9
jog_cont = [False] * 9
jogging = [0] * 9
with this
def jog(*args):
if not manual_tab_visible(): return
isHomed=True
for i,h in enumerate(s.homed):
if s.axis_mask & (1<<i):
isHomed=isHomed and h
if not isHomed: return
c.jog(*args)
jogging = [0] * 9
10 Feb 2012 13:49 - 10 Feb 2012 13:49 #17557
by BigJohnT
Replied by BigJohnT on topic Re:I can runing jog before homing on axis shell
Can you do that with .axisrc and not have to worry about upgrades over writing your changes?
Last edit: 10 Feb 2012 13:49 by BigJohnT.
10 Feb 2012 15:40 - 10 Feb 2012 15:41 #17565
by ArcEye
Hi John
Probably not, as I am changing an existing function definition to include a test as to whether the axes are homed before allowing jogs.
The other code I have seen for .axisrc seems to be using global tk calls, or defining a function and then calling it, rather than modifying a built in Axis function
I can generally work out what python code is doing and make adjustments but I am not a python programmer.
Can't imagine many people would have a use for this, I like to jog near home and then Ctrl H to home everything, not stand around watching one or more axis move long distances at a slow homing velocity.
Just posted it to show it was possible.
Last edit: 10 Feb 2012 15:41 by ArcEye.
10 Feb 2012 15:51 #17570
by BigJohnT
Thanks,
I was just wondering out loud if you could do that. I'm not a python programmer but managed to write some simple G code generators on the wiki after much example searching
Time to create page: 0.189 seconds
