2 servos 1 stepper
14 years 3 months ago #21546 by arthur
2 servos 1 stepper was created by arthur
Ok, Im building a "Frankenstein" CNC mill from an MFP and printer. So its 2 servos and one stepper. X and Z are servo, and Y is stepper.
I have gotten the servos mostly working in "Etch-Servo". X needs some tuning, giving follow error, Z is good.
Stepper also works in Stepconf.
Now I have two saved "machines" that need to be combined. What would be the best way to do this?
14 years 3 months ago #21547 by cncbasher
Replied by cncbasher on topic 2 servos 1 stepper
you dont state how your hardware is connected ... parrell port or mesa io card etc ...
it''s realy just a matter of combining the 2 hal files , follow error is probably just a tuning matter or increase follow error value in INI file
post your hal files would be a good starting point
14 years 3 months ago #21557 by andypugh
Replied by andypugh on topic 2 servos 1 stepper
You can very nearly just transfer the HAL file from one configuration into the config directory of the other, and then add the filename of the second HAL file to the INI.
It isn't quite that simple as you will need to remove duplicated lines from the second HAL file, but that is nearly all that there is to it.
14 years 3 months ago #21563 by arthur
Replied by arthur on topic 2 servos 1 stepper
Sorry, I posted at 3am. But They all go through the parallel port. The two servos to a dual h bridge, and the stepper to its own dual h bridge and simple driver circuit.
I'll post the hal and ini files in a few.
14 years 3 months ago - 14 years 3 months ago #21565 by arthur
Servo .hal
# load realtime modules # kinematics loadrt trivkins loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hal_parport cfg="1030" loadrt encoder num_chan=2 loadrt pid num_chan=2 loadrt pwmgen output_type=1,1 loadrt ddt count=4 loadrt constant count=1 # define the order of execution for RT code addf parport.0.read base-thread addf encoder.update-counters base-thread addf pwmgen.make-pulses base-thread addf parport.0.write base-thread addf encoder.capture-position servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.0.do-pid-calcs servo-thread addf pid.1.do-pid-calcs servo-thread addf constant.0 servo-thread addf pwmgen.update servo-thread addf ddt.0 servo-thread addf ddt.1 servo-thread addf ddt.2 servo-thread addf ddt.3 servo-thread # hook stuff together setp encoder.0.position-scale [AXIS_0]INPUT_SCALE setp encoder.1.position-scale [AXIS_1]INPUT_SCALE net enc0A encoder.0.phase-A <= parport.0.pin-10-in net enc0B encoder.0.phase-B <= parport.0.pin-11-in net enc1A encoder.1.phase-A <= parport.0.pin-12-in net enc1B encoder.1.phase-B <= parport.0.pin-13-in net Xpos-fb <= encoder.0.position net Ypos-fb <= encoder.1.position net Xpos-fb => pid.0.feedback net Ypos-fb => pid.1.feedback net Xpos-fb => axis.0.motor-pos-fb net Ypos-fb => axis.1.motor-pos-fb net Xvel-cmd <= pid.0.output net Yvel-cmd <= pid.1.output net Xvel-cmd => pwmgen.0.value net Yvel-cmd => pwmgen.1.value net Xpwm pwmgen.0.pwm net Ypwm pwmgen.1.pwm net Xdir <= pwmgen.0.dir net Ydir <= pwmgen.1.dir net Xdir => parport.0.pin-06-out net Xdir => parport.0.pin-07-out setp parport.0.pin-07-out-invert TRUE net Xpwm => parport.0.pin-05-out net Ydir => parport.0.pin-03-out net Ydir => parport.0.pin-04-out setp parport.0.pin-04-out-invert TRUE net Ypwm => parport.0.pin-02-out setp pid.0.maxoutput 1.0 setp pid.1.maxoutput 1.0 # the values below come from the ini setp pid.0.Pgain [AXIS_0]P setp pid.0.Igain [AXIS_0]I setp pid.0.Dgain [AXIS_0]D setp pid.0.bias [AXIS_0]BIAS setp pid.0.FF0 [AXIS_0]FF0 setp pid.0.FF1 [AXIS_0]FF1 setp pid.0.FF2 [AXIS_0]FF2 # deadband should be just over 1 count setp pid.0.deadband [AXIS_0]DEADBAND setp pid.1.Pgain [AXIS_1]P setp pid.1.Igain [AXIS_1]I setp pid.1.Dgain [AXIS_1]D setp pid.1.bias [AXIS_1]BIAS setp pid.1.FF0 [AXIS_1]FF0 setp pid.1.FF1 [AXIS_1]FF1 setp pid.1.FF2 [AXIS_1]FF2 # deadband should be just over 1 count setp pid.1.deadband [AXIS_1]DEADBAND net Xpos-cmd <= axis.0.motor-pos-cmd net Ypos-cmd <= axis.1.motor-pos-cmd net Xpos-cmd => pid.0.command net Ypos-cmd => pid.1.command net Xenable <= axis.0.amp-enable-out net Yenable <= axis.1.amp-enable-out net Xenable => pid.0.enable net Xenable => pwmgen.0.enable net Yenable => pid.1.enable net Yenable => pwmgen.1.enable net estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in net Xpos-cmd => ddt.0.in net Xvel <= ddt.0.out net Xvel => ddt.1.in net Xacc <= ddt.1.out net Ypos-cmd => ddt.2.in net Yvel <= ddt.2.out net Yvel => ddt.3.in net Yacc <= ddt.3.out net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
servo .ini
# EMC controller parameters for generic controller. Make these what you need # for your system. # General note: Comments can either be preceded with a # or ; - either is # acceptable, although # is in keeping with most linux config files. # Settings with a + at the front of the comment are likely needed to get # changed by the user. # Settings with a - at the front are highly unneeded to be changed ############################################################################### # General section ############################################################################### [EMC] #- Version of this INI file VERSION = $Revision$ #+ Name of machine, for use with display, etc. MACHINE = LinuxCNC-ETCH-SERVO #+ Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others DEBUG = 0 # DEBUG = 0x00000007 # DEBUG = 0x7FFFFFFF ############################################################################### # Sections for display options ############################################################################### [DISPLAY] #+ Name of display program, e.g., xemc DISPLAY = axis # DISPLAY = usrmot # DISPLAY = mini # DISPLAY = tkemc # Cycle time, in seconds, that display will sleep between polls CYCLE_TIME = 0.200 #- Path to help file HELP_FILE = doc/help.txt #- Initial display setting for position, RELATIVE or MACHINE POSITION_OFFSET = RELATIVE #- Initial display setting for position, COMMANDED or ACTUAL POSITION_FEEDBACK = ACTUAL #+ Highest value that will be allowed for feed override, 1.0 = 100% MAX_FEED_OVERRIDE = 10 #- Prefix to be used PROGRAM_PREFIX = /home/arthur/linuxcnc/nc_files #- Introductory graphic INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 # Editor to be used with Axis EDITOR = gedit ############################################################################### # Task controller section ############################################################################### [TASK] # Name of task controller program, e.g., milltask TASK = milltask #- Cycle time, in seconds, that task controller will sleep between polls CYCLE_TIME = 0.010 ############################################################################### # Part program interpreter section ############################################################################### [RS274NGC] #- File containing interpreter variables PARAMETER_FILE = etch.var ############################################################################### # Motion control section ############################################################################### [EMCMOT] #- Name of the motion controller to use (only one exists for nontrivkins) EMCMOT = motmod #- Timeout for comm to emcmot, in seconds COMM_TIMEOUT = 1.0 #- Interval between tries to emcmot, in seconds COMM_WAIT = 0.010 #+ Base task period, in nanosecs - this is the fastest thread in the machine BASE_PERIOD = 20000 #- Servo task period, in nanosecs - will be rounded to an int multiple of BASE_PERIOD SERVO_PERIOD = 1000000 ############################################################################### # Hardware Abstraction Layer section ############################################################################### [HAL] # The run script first uses halcmd to execute any HALFILE # files, and then to execute any individual HALCMD commands. # # list of hal config files to run through halcmd #+ files are executed in the order in which they appear HALFILE = etch.hal #- list of halcmd commands to execute # commands are executed in the order in which they appear #HALCMD = save neta ############################################################################### # Trajectory planner section ############################################################################### [TRAJ] #+ machine specific settings AXES = 3 # COORDINATES = X Y Z A B C COORDINATES = X Y z HOME = 0 0 0 LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 1 MAX_VELOCITY = 30 DEFAULT_ACCELERATION = 15.0 MAX_ACCELERATION = 20.0 ############################################################################### # Axes sections ############################################################################### #+ First axis [AXIS_0] TYPE = LINEAR HOME = 0.000 MAX_VELOCITY = 10 MAX_ACCELERATION = 5 BACKLASH = 0.000 INPUT_SCALE = 500 OUTPUT_SCALE = 500.000 MIN_LIMIT = 0.0 MAX_LIMIT = 6 FERROR = 0.2 MIN_FERROR = 0.10 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 0.0 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = NO P = 10 I = 100 D = 0 BIAS = 0.0 FF0 = 0 FF1 = 1000 FF2 = 0 DEADBAND=.002 #+ Second axis [AXIS_1] TYPE = LINEAR HOME = 0.000 MAX_VELOCITY = 10 MAX_ACCELERATION = 5 BACKLASH = 0.000 INPUT_SCALE = 500 OUTPUT_SCALE = 500.000 MIN_LIMIT = 0 MAX_LIMIT = 20 FERROR = 0.200 MIN_FERROR = 0.100 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 0.0 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = NO P = 10 I = 200 D = 0.1 BIAS = 0.0 FF0 = 4 FF1 = 1 FF2 = 0.0 DEADBAND=.002 #+ Third axis [AXIS_0] TYPE = LINEAR HOME = 0.000 MAX_VELOCITY = 100 MAX_ACCELERATION = 200 BACKLASH = 0.000 INPUT_SCALE = 200 OUTPUT_SCALE = 1.000 MIN_LIMIT = 0.0 MAX_LIMIT = 6.5 FERROR = 0.2 MIN_FERROR = 0.10 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0.0 HOME_LATCH_VEL = 0.0 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = NO P = 150 I = 100 D = 0.1 BIAS = 0.0 FF0 = 0 FF1 = 1 FF2 = 0.0 DEADBAND=.002 ############################################################################### # section for main IO controller parameters ############################################################################### [EMCIO] #- Name of IO controller program, e.g., io EMCIO = io #- cycle time, in seconds CYCLE_TIME = 0.100 #- tool table file TOOL_TABLE = etch.tbl
stepper .hal
# Generated by stepconf at Wed Mar 15 02:19:04 2000 # If you make changes to this file, they will be # overwritten when you run stepconf again loadrt trivkins loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt probe_parport loadrt hal_parport cfg="1030 out " setp parport.0.reset-time 5000 loadrt stepgen step_type=0,0,0 addf parport.0.read base-thread addf stepgen.make-pulses base-thread addf parport.0.write base-thread addf parport.0.reset base-thread addf stepgen.capture-position servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf stepgen.update-freq servo-thread net spindle-cmd <= motion.spindle-speed-out net ystep => parport.0.pin-08-out setp parport.0.pin-08-out-reset 1 net ydir => parport.0.pin-09-out setp stepgen.0.position-scale [AXIS_0]SCALE setp stepgen.0.steplen 1 setp stepgen.0.stepspace 0 setp stepgen.0.dirhold 21000 setp stepgen.0.dirsetup 21000 setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb net xstep <= stepgen.0.step net xdir <= stepgen.0.dir net xenable axis.0.amp-enable-out => stepgen.0.enable setp stepgen.1.position-scale [AXIS_1]SCALE setp stepgen.1.steplen 1 setp stepgen.1.stepspace 0 setp stepgen.1.dirhold 21000 setp stepgen.1.dirsetup 21000 setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb net ystep <= stepgen.1.step net ydir <= stepgen.1.dir net yenable axis.1.amp-enable-out => stepgen.1.enable setp stepgen.2.position-scale [AXIS_2]SCALE setp stepgen.2.steplen 1 setp stepgen.2.stepspace 0 setp stepgen.2.dirhold 21000 setp stepgen.2.dirsetup 21000 setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb net zstep <= stepgen.2.step net zdir <= stepgen.2.dir net zenable axis.2.amp-enable-out => stepgen.2.enable net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in loadusr -W hal_manualtoolchange net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
stepper .ini
# Generated by stepconf at Wed Mar 15 02:19:04 2000 # If you make changes to this file, they will be # overwritten when you run stepconf again [EMC] MACHINE = my-mill DEBUG = 0 [DISPLAY] DISPLAY = axis EDITOR = gedit POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 1.2 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/arthur/linuxcnc/nc_files INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 BASE_PERIOD = 100000 SERVO_PERIOD = 1000000 [HAL] HALFILE = my-mill.hal HALFILE = custom.hal POSTGUI_HALFILE = custom_postgui.hal [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 0.10 MAX_LINEAR_VELOCITY = 1.00 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_0] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 STEPGEN_MAXACCEL = 37.5 SCALE = 8000.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -0.01 MAX_LIMIT = 8.0 HOME_OFFSET = 0.0 [AXIS_1] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 0.9 MAX_ACCELERATION = 0.9 STEPGEN_MAXACCEL = 1.125 SCALE = 1248.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -0.01 MAX_LIMIT = 8.0 HOME_OFFSET = 0.0 [AXIS_2] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 STEPGEN_MAXACCEL = 37.5 SCALE = 8000.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -4.0 MAX_LIMIT = 0.01 HOME_OFFSET = 0.0
Last edit: 14 years 3 months ago by arthur.
14 years 3 months ago #21566 by arthur
Ok, I copied over the stepper part to the servo file's, renumbered the axis I will try it in a few and report back.
Time to create page: 0.339 seconds
