Step/Dir Servo?
- Topic Author
- Thank you received: 1369
06 Sep 2012 03:47 #23957
Step/Dir Servo? was created by Todd Zuercher
Is there any advantage to having encoder feedback in a system using step/dir servos?
06 Sep 2012 04:17 #23958
Replied by PCW on topic Re:Step/Dir Servo?
One advantage is that you could keep track of the
following error
It could also be used for a dual feedback system
with the step/dir servo+rotary encoder functioning
as a velocity mode drive getting position feedback
from a linear encoder and LinuxCNCs PID loop.
following error
- Topic Author
06 Sep 2012 13:24 #23975
Replied by Todd Zuercher on topic Re:Step/Dir Servo?
Pardon my ignorance, but could you explain how a step/dir drive can be used as a velocity mode drive? Could that be done without the linear encoder, just the motors rotary one?
06 Sep 2012 15:42 #23983
You set LinuxCNC's stepgen to velocity mode,
now your external step/dir servo is a velocity mode
drive as far as LinuxCNC is concerned.
This like an analog velocity mode servo except that the
velocity command is a step rate and a direction
The fact that the drive is maintaining a position loop can
be ignored as long as you dont exceed its capabilities
I dont know if there is any advantage of velocity mode
if a single encoder is used
07 Sep 2012 03:02 #23997
by aike
Replied by aike on topic Re:Step/Dir Servo?
I use the same scheme, plus USE_INDEX to make exactly homing.
Time to create page: 0.093 seconds
