input error and stop the running program
12 Oct 2012 07:44 #25261
by RomainM
input error and stop the running program was created by RomainM
I'm Romain, I live in France and I'm a newbie in Linux and Linux CNC.
I'm finishing to build my gantry CNC Machine (X 2800 mm, Y 1500 mm (gantry), Z 200mm). The X and Y are moved by racks and pinions and Z by ball screw. I use 4 x 130W servo motor with Heidenhain Rod 426 encoder for alls axis drived by 4 CNC drive DG2S. I tune the PID directly on the DG2S drives and I just configure Linux CNC like I used stepper motors.
When a drive detect an error, it stop alls the other drives and , It create a error input on the pin 10 of my parallel port.
I would like to stop the running program when this pin is high. I'm not very comfortable with HAL.
Could you help me to write this lines ?
Thanks for your help.
12 Oct 2012 10:40 #25264
by BigJohnT
Replied by BigJohnT on topic Re:input error and stop the running program
This is the hal lines for an external e-stop input that I recently did for a machine.
This is what you might have now:
I recommend that you read this short introduction to hal or the french version although it seems to be missing some graphics.
# estop
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= hm2_5i20.0.gpio.025.in_not
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
- Thank you received: 1369
12 Oct 2012 17:58 #25274
Replied by Todd Zuercher on topic Re:input error and stop the running program
The axis.namp-fault-in will stop the exicution of a move or program, place the machine in power off, and gives an error message at the bottom of the screen.
Here is how I handled a fault signal from the drives on a machine:
net Xfault-in pcl720.0.pin-26-in => not.0.in
net Xfault not.0.out => axis.0.amp-fault-in
net Yfault-in pcl720.0.pin-24-in => not.1.in
net Yfault not.1.out => axis.1.amp-fault-in
net Zfault-in pcl720.0.pin-02-in => not.2.in
net Zfault not.2.out => axis.2.amp-fault-in
You would probably use somthing like this:
net Xfault-in parport.0.pin-10-in => axis.0.amp-fault-in
(assuming that this drive is connected to your first parallel port and the first or X axis)
12 Oct 2012 20:37 #25277
by RomainM
Replied by RomainM on topic Re:input error and stop the running program
Thanks guys, I'll probably test this tomorrow and I'll tell you if it will works.
Romain
Romain
12 Oct 2012 20:39 #25278
by BigJohnT
I don't have a clue what I was thinking of, Todd is spot on.
