Joint 0 on limit switch
- paulstenlund
30 Oct 2012 08:00 #26041
by paulstenlund
Joint 0 on limit switch was created by paulstenlund
I gave up on 10.4 and went back to 6.061. Stepconf works great - back and forth up and down. When I try to run Axis I get:
Joint 0 on limit switch error
Joint 1 on limit switch error
Joint 2 on limit switch error
I got no limit switchs man.
What could be wrong - runs in sim mode? I've tried increasing table size in step config. I have several 6. cds may i'll install a diiferent one?
Paul
Paul
30 Oct 2012 14:52 - 30 Oct 2012 15:01 #26046
by Rick G
Replied by Rick G on topic Joint 0 on limit switch
Have you tried 8.04? It seems to work on many computers that 10.04 will not.
What version of EMC2 are you running?
When you run Stepconf are you selecting parallel port pins for limit switches? If you do not have them try not selecting them, or try inverting them.
Are you creating a new config with Stepconf or loading an existing config? If experimenting with different configs select one without limit switches.
Rick G
Rick G
Last edit: 30 Oct 2012 15:01 by Rick G.
- paulstenlund
30 Oct 2012 15:26 #26047
by paulstenlund
Replied by paulstenlund on topic Joint 0 on limit switch
Rick
set them to unused and it worked in Live mode, installing now. Thanks a million. I tried 8.04 and it locks up after displaying the Penguin. People think its the video card any ideas? What cards work in a old Dell?
Thanks again
Paul
Thanks again
Paul
30 Oct 2012 16:51 #26049
by Rick G
Glad to hear you are up and running.
Have you looked here?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oting#Display_Issues
Rick G
Rick G
30 Oct 2012 20:15 #26060
It is probably worth investing a little time in trying to get 8.04 to work.
Replied by andypugh on topic Joint 0 on limit switch
Unfortunately you will be stuck on EMC2 v 2.3 with that version of Ubuntu (as far as I can tell).I gave up on 10.4 and went back to 6.061
15 Jan 2013 18:25 #28718
by marsheng
Replied by marsheng on topic Joint 0 on limit switch
I'm running 2.5.1 and I cannot get past joint 1 on limit switch error. I tried inverting the inputs but made no difference. So where to now ?
Thanks Wallace
Thanks Wallace
15 Jan 2013 20:01 #28722
by ArcEye
Replied by ArcEye on topic Joint 0 on limit switch
You will have to post your .ini and .hal file.
What happens if you just put a link across the appropriate terminals on the Joint 1 limit switch connectors? ie have you eliminated wiring faults?
16 Jan 2013 03:45 #28733
by marsheng
I'm running it all on testbed and we have switches for the inputs which are working in the pnconfig.
16 Jan 2013 04:04 - 16 Jan 2013 04:14 #28735
Replied by PCW on topic Joint 0 on limit switch
it should be easy to trace this by starting linuxcnc and 'watching'
axis.0.neg-lim-sw-in and axis.0.pos-lim-sw-in
via machine --> show hal configuration --> pins --> axis --> 0 --> neg-lim-sw-in
and machine --> show hal configuration --> pins --> axis --> 0 --> pos-lim-sw-in
menu selections
BTW the PWM output type is wrong for a 7I48. 7I48 needs PWM type 2
menu selections
Last edit: 16 Jan 2013 04:14 by PCW. Reason: addenda
16 Jan 2013 06:07 #28738
by marsheng
PncConf only gives the following options.
Pulse Width Gen-P
Pulse Density-P
Up/Down Mode - Up
Am I in the wrong place ?
Pulse Width Gen-P
Pulse Density-P
Up/Down Mode - Up
Time to create page: 0.134 seconds
