encoder error
15 Nov 2012 00:12 #26586
by jlviloria
encoder error was created by jlviloria
Now I turned my machine, I get the following error:
hm2/hm2_5i25.0: Encoder4:quadrature count error
This error can result?
The only new thing I had done was to enable the home and limit switch.
X values are very high position.
thanks
thanks
15 Nov 2012 00:21 #26588
Replied by PCW on topic encoder error
A 'quadrature count error' indicates that the input section of the
quadrature counter saw A and B change simultaneously (which is illegal for quadrature)
This usually indicates some kind of noise coupled into both A/B encoder inputs
at the same time.
Do you have the encoder filter turned on? (man hostmot2 in encoder section)
and are you using encoder 4?
at the same time.
15 Nov 2012 00:44 - 15 Nov 2012 00:48 #26589
by jlviloria
Replied by jlviloria on topic encoder error
encoder filter you mean this?
setp "hm2_5i25.0.encoder.00.filter 1"
not what you mean with encoder 4.
encoder is a "2000 pulses" and that I should scale well multiply by 4 the value of the scale. That would Encoder 4?
The only thing odd about the machine move was to enable him home and limit switch
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -0.050000
HOME_LATCH_VEL = -0.016667
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = yes
HOME_SEQUENCE = 1
both axes are giving erroneous measurements
HOME_SEQUENCE = 1
Last edit: 15 Nov 2012 00:48 by jlviloria.
15 Nov 2012 01:05 - 15 Nov 2012 01:09 #26590
The error was with encoder number 4 (out of 0,1,2,3,4,5)
If this encoder is not used I would suspect you have caused
some kind of wiring problem.
I would un-do your last changes and see if you can trace whats gone wrong
especially if the measurements were OK and are now wrong
Last edit: 15 Nov 2012 01:09 by PCW. Reason: sp
15 Nov 2012 02:25 #26593
by jlviloria
Peter.
I think I found the problem.
I update my linuxcnc to 2.6.0-pre. to install a. patch (fanuc-change-tools).
My setup is in mm.
when input the machine moves 1mm but my encoder is registering 25.4mm. but machine if move 1mm.
in inch view if you move the 0.0393" that corresponds to 1mm
linuxcnc be that this corrupt?
thanks
My setup is in mm.
thanks
15 Nov 2012 21:37 #26620
That's a different problem.
Can you answer PCWs question: Are you using encoder 4?
It seems unlikely that you would be using the 5th encoder on a lathe (encoders are numbered from 0, so encoder.04. is the 5th one). Perhaps you mis-wired a switch into the encoder connector?
Replied by andypugh on topic encoder error
Time to create page: 0.087 seconds
