Card for Parallel Port with 2 PWM or Analog Output
30 Nov 2012 23:51 #27101
by mmt
Card for Parallel Port with 2 PWM or Analog Output was created by mmt
Does anyone have any idea if or where I might find such a thing?
Building a system that requires 3 PWM outputs. Breakout board I am using has 1 so I need a card that I can hook to a second parallel port that has at least 2.
Thanks,
Kent
Thanks,
Kent
01 Dec 2012 00:48 #27102
by cncbasher
Replied by cncbasher on topic Card for Parallel Port with 2 PWM or Analog Output
you would probably be better with a Mesa 7I43 , and 7I42 addon's for use with a parrell port , that will give you all you need you'll get 48 pins in total
more than you'll ever get with a parallel port on it's own .
can you give more details on the units you are connecting , for analog out you can just add a basic filter to the pwm output
06 Dec 2012 00:01 #27252
by mmt
Replied by mmt on topic Card for Parallel Port with 2 PWM or Analog Output
Thanks. It is a laser system. I need 3 analog outputs. Spindle, Power supply, and Q switch all are 0-10VDC Analog In.
06 Dec 2012 09:29 #27277
Replied by andypugh on topic Card for Parallel Port with 2 PWM or Analog Output
If you don't have a spare PCI slot then the 7i43 looks like the thing to use. It has a lot more tricks than just PWM, it can handle all your steppers and encoders too.Thanks. It is a laser system. I need 3 analog outputs. Spindle, Power supply, and Q switch all are 0-10VDC Analog In.
Time to create page: 0.454 seconds
