Axis startup in metric.
01 Dec 2012 04:02 #27107
by sliptonic
Axis startup in metric. was created by sliptonic
My mill is configured with imperial native units but I work exclusively in metric. When I start axis, I have to go to the View menu and select "display mm" or else the manual touch-off values I enter are in the wrong unit.
I see settings in the .ini file TRAJ section for linear_units but this seems to control the machine native units. How can I make axis start up in metric mode without converting the native units?
01 Dec 2012 13:29 #27112
Replied by cmorley on topic Axis startup in metric.
In your INI file under [DISPLAY] add
POSITION_UNITS = mm
I didn't test much but the display is set to metric
This seems undocumented
Chris M
POSITION_UNITS = mm
Chris M
01 Dec 2012 20:48 #27115
by BigJohnT
Replied by BigJohnT on topic Axis startup in metric.
Using POSITION_UNITS = mm could lead to some confusion as it leaves the feed overrides in inch and also leaves the default units at G20. So if you do a G0 X25 expecting it to go 25mm you will be in for a surprise when it tries to go 635mm.
A much better solution is to use LINEAR_UNITS = mm and take the few minutes to convert your config to mm.
02 Dec 2012 05:14 #27118
by Rick G
Replied by Rick G on topic Axis startup in metric.
Would it also be a good idea in the [RS274NGC] Section of the ni file to add G21 ?
RS274NGC_STARTUP_CODE = G21
Rick G
Rick G
Time to create page: 0.082 seconds
