Plasma THC300 Z Axis trouble
04 Dec 2012 23:30 - 05 Dec 2012 20:23 #27203
by the_muck
Plasma THC300 Z Axis trouble was created by the_muck
Hallo,
sorry for my bad englisch .
I start to config EMC for Plasma cutting and have a lot of trouble. I use the basic config plasma THC300, changed Ports, Axis speeds, Limits...
When i make in World mode a new 0 Point, the Z Axis Move Down from +150 to 0 and back to +150, that is wehen i zero any axis. and i can not adjust the Speed of the Z Axis when they do this. So it is not possible to zero. Where is the point to set the "length" to the Float Switsch and is there a Documentation for this config?
The A motor not jog in Joint Mode by hand, thats very bad wenn the A axis not jog.
What make Travel Height and Sw. Travel?
Edit:
I have make a new config. with plasma THC300, just invert the estop and float switch pin that it runs. The same problem, when i make a 0 point the Z axis value in Linux CNC move up and down!
Edit:
Last edit: 05 Dec 2012 20:23 by the_muck.
10 Dec 2012 19:54 #27502
Sorry for the delay in replying.
Does this still happen with the THC disabled? am wondering if it is something wierd with the way that THC "lies" about the Z-position to the rest of the system.
Does the actual Z axis move, or just the DRO?
Replied by andypugh on topic Plasma THC300 Z Axis trouble
10 Dec 2012 20:53 #27507
by BigJohnT
Replied by BigJohnT on topic Plasma THC300 Z Axis trouble
He's using the THC300 config and the THC control is all done with hundreds of HAL components. It's so complex that it includes an Open Office Drawing that needs to be printed out on a D size plotter. I never could follow the logic of that one.
10 Dec 2012 20:59 #27508
Is there a simpler sample config using the THC component?
10 Dec 2012 21:02 #27509
by BigJohnT
Yes, the Plasma 5i20 config is what I used until I converted to a 5i25 7i76.
11 Dec 2012 17:38 #27565
by the_muck
Replied by the_muck on topic Plasma THC300 Z Axis trouble
Hallo,
now i have changed to try a nother config, there is no documentation for THC 300 and i cant understand how it works and what the problem is.
linuxcnc.org/lucid/emc2/index.php/forum/...2&lang=italian#15198
you need the LinuxCNC dev package, and install the *.comp file.
In this moment it works not 100%, but i think it is better to understand.
Time to create page: 0.090 seconds
