Minimum requirements to run comp
19 Dec 2012 00:49 #27838
by mariusl
Regards
Marius
www.bluearccnc.com
Minimum requirements to run comp was created by mariusl
Can someone tell me what I have to install as a minimum to be able to run comp please I am on a customers machine an I dont want to put the whole source on it.
Regards
Marius
www.bluearccnc.com
19 Dec 2012 01:40 #27842
by ArcEye
Replied by ArcEye on topic Minimum requirements to run comp
Hi
You need the emc2-dev package of emc2 to get comp, but if you have linuxcnc (2.5 or later) all the dev files including comp are now part of it.
You can probably just apt-get install build-essentials to get comp running.
Depends what your component links to, as to whether you need more than just the kernel headers from a basic install and the includes from /usr/realtime-xxxx/include.
19 Dec 2012 03:00 #27844
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Minimum requirements to run comp
ArcEye
I gathered as much so I just installed the dev package. I suppose it does not matter to much if the dev is on the machine as well.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.071 seconds
