How to link toolchange to parport
- Bad_German
20 Dec 2012 15:54 #27888
by Bad_German
How to link toolchange to parport was created by Bad_German
Hi, I am trying to setup a 8 position toolchanger (lathe, turret type), which will be controlled by a PIC microcontroller.
I have been searching around and cannot find detailed information on this.
Firstly I want to ignore tool-prepare so:
this line is active in the standard_pinout.hal
Next I want to link the:
tool-change to a parport pin, and the
input parport pin to the tool-changed pin.
I know I am probably missing a whole lot of stuff here but this is what I have so far.
net tool-change iocontrol.0.tool-change => parport.0.pin-10-out
net tool-changed iocontrol.0.tool-changed <= parport.0.pin-11-in
I get a error of: paraport.0.pin-10-out does not exist , how do I correctly define it?
also what type of signal is used to communicate the tool number to the parallel port, and what confirmation signal is used in return?
I found this but to me it is not clear enough on the exact signal to read and send to the micro-controller at the tool-turret.
Please can you help me with the setup, or point me in the right direction.
20 Dec 2012 18:13 #27892
by ArcEye
Replied by ArcEye on topic How to link toolchange to parport
Hi
Have a look at these components
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...oolchanger_component
I wrote these for 8 tool ATCs, the difference was that the first has a locking pawl and you just move the relevant number of positions then reverse to lock,
the second has a grey scale truth table to identify the tool number, which needs to be decoded, then the motor is reversed until against the pawl.
You can see the signal sequences from the operation of the components.
It would be easiest for you to take a similar component path, even if you feed the output signal to a separate controller rather than dealing with it directly.
Expect you will have queries, would be helpful to know what lathe and what sort of ATC (pneumatic, mechanical)
I think JT has a classic ladder routine for a lathe with a lot of solenoids, air feeds, sensors etc on the ATC. (possibly a Mori)
The following user(s) said Thank You: Bad_German
- Bad_German
20 Dec 2012 19:16 - 20 Dec 2012 19:26 #27894
by Bad_German
Replied by Bad_German on topic How to link toolchange to parport
Thanks for the info, I will work through it later.
The lathe I am using is a EMCO Turn120,
The toolchanger works with a DC motor that turns the turret CW into position and locks it CCW, there are 4 position sensors for the current position feedback.
I was planning on doing this:
on the T(X)M6 command send a high voltage for (X)ms on a parallel port pin,then an external pic reads that using an interrupt and a timer, using this info it can then select the right tool and send a short high signal back through another parallel port pin to confirm it has completed the toolchange.
Last edit: 20 Dec 2012 19:26 by Bad_German.
20 Dec 2012 20:17 #27895
by BigJohnT
Replied by BigJohnT on topic How to link toolchange to parport
I think my turret ladder is very close to yours for my Hardinge. Tn M6 if the Tn is different starts the turret turning till the encoder number is the same as Tn then when the turret is back down it reports success back to LinuxCNC.
gnipsel.com/shop/hardinge/hardinge.xhtml
20 Dec 2012 20:52 #27897
by cncbasher
Replied by cncbasher on topic How to link toolchange to parport
if using linuxcnc 2.5.1 the orac toolchanger comp as arceye has mentioned is essentialy the same toolchanger as the emco .
and the bonus is if you have enough pins available then you can drive directly from linuxcnc and not need the pic micro ..
I used 2 relays for forward / reverse and run
and used the built in opto decoder for positioning
- Bad_German
20 Dec 2012 21:54 - 21 Dec 2012 00:09 #27902
by Bad_German
WOW, Thanks for your help guys
going to use the orac toolchanger component,
looks like I only have to add Opto4 and redo the truth table, to adopt ArcEye's work to my EMCO.
Will post the final product, or when I get stuck.
Stephan
Stephan
Last edit: 21 Dec 2012 00:09 by Bad_German.
- Bad_German
27 Dec 2012 20:44 #28088
by Bad_German
All done, tested and working.
mods to work on the emco turn 120:
added 4th opto,
update truth table,
reverse lock stays on and pwm's the output for current control in the DC motor, as the tool turret has significant backlash.
e-stop also stops the tool change
added 4th opto,
update truth table,
27 Dec 2012 21:07 #28089
by cncbasher
great news , glad you have it working , hope it was not to painful .
look forward to see your changes .
27 Dec 2012 21:11 #28090
by ArcEye
Glad it worked for you.
Dont forget to add it with a short write up to the Contributed Components section of the Wiki
(or post it here and I will add it if you want)
- Bad_German
27 Dec 2012 22:07 #28092
by Bad_German
ArcEye, after looking over it, please add it to the correct section.
Time to create page: 0.425 seconds
