Axis: 'Touch Off' disabled
27 Dec 2012 04:55 #28062
by rmrf
Axis: 'Touch Off' disabled was created by rmrf
I am using a machine configuration derived from the 'gantry' simulator configuration.
I'd like to use the 'Touch Off' button in the manual control dialog of the Axis UI, but it remains disabled after homing. The 'touch off' button works for me with different (simulator) configurations (axis.ini for example). Like in my derived config, it is not usable in the unmodified gantry simulator configuration as shipped with linuxcnc.
So my question is how ini or HAL configuration determines whether the "Touch off" button in AXIS is available or not.
27 Dec 2012 05:18 #28063
by BigJohnT
Replied by BigJohnT on topic Axis: 'Touch Off' disabled
In addition to the power being on I think you have to be in joint mode or something like that.
The following user(s) said Thank You: rmrf
27 Dec 2012 15:09 #28076
by rmrf
Replied by rmrf on topic Axis: 'Touch Off' disabled
Thanks, that solved it
Time to create page: 0.188 seconds
