Tool change manually - how calibrate now tool?
- raimund.reh
05 Jan 2013 21:32 - 05 Jan 2013 21:33 #28400
by raimund.reh
Tool change manually - how calibrate now tool? was created by raimund.reh
coming from WINPC-NC light means changing tools manually.
Here milling pcb-board insolation - after that having different wholes to drill.
Any hints or tips?
thanks for any help!
Any hints or tips?
Last edit: 05 Jan 2013 21:33 by raimund.reh.
05 Jan 2013 22:25 #28401
by Rick G
Replied by Rick G on topic Tool change manually - how calibrate now tool?
Have you read up in the documentation on setting up the tool table?
Rick G
Rick G
- raimund.reh
06 Jan 2013 17:30 #28409
by raimund.reh
Replied by raimund.reh on topic Tool change manually - how calibrate now tool?
I do (User Manual V2.5, 2013-01-03
- Chpt: 10.4, 10.5) - they are rather short and maybe helpfull for the writer of this chapters.
Any further hints?
Any further hints?
06 Jan 2013 22:52 #28415
by Rick G
As I do not have an automatic tool changer on my mill or an accurate / repeatable way to set my tool lengths if I need to mill and then drill with different tooling I separate the program into two steps, 1 mill and 2 drill.
So...
Load the milling program.
Install the milling tool
"touch off" to set it's length.
Run the milling program.
Stop the machine.
Load the drilling program.
Install the drill
"touch off" the drill to set it's length.
Run the drilling program.
Rick G
So...
Stop the machine.
Install the drill
Rick G
07 Jan 2013 01:07 - 07 Jan 2013 23:39 #28420
by BigJohnT
I apologize in advance for the following reply...
Best hint I have is RTFM then ask a real question... Here is a
link
to my tutorial.
Replied by BigJohnT on topic Tool change manually - how calibrate now tool?
Any further hints?
Last edit: 07 Jan 2013 23:39 by BigJohnT. Reason: add missing link
- raimund.reh
07 Jan 2013 23:01 #28444
by raimund.reh
I think for a dummy like me this will be the choise! Thank you!
Time to create page: 0.398 seconds
