Mesa 7i48 servo card - no input signal.
15 Jan 2013 04:15 #28702
Replied by PCW on topic Mesa 7i48 servo card - no input signal.
OK the FPGA configuration file is in the HAL file since this setup
was created with pncconf.
The configuration is here:
loadrt hm2_pci config="firmware=hm2/5i20/SVST8_4.BIT num_encoders=3 num_pwmgens=3
(SVST8_4.BIT) which is not the correct FPGA configuration for a 7I48
Does pncconf have a option to select a 7I48 daughtercard?
15 Jan 2013 04:47 #28703
by marsheng
Replied by marsheng on topic Mesa 7i48 servo card - no input signal.
Phew - we changed the firmware option and it worked. Nearly 3 days to get this to run.
Ok so which is the correct one.
I have
5I20 7I37 7I48
SV12
SV12_2X7I48_72
SV12IN_2X7I48_72
There are other options but these seem the most logical.
I have
5I20 7I37 7I48
SV12
SV12_2X7I48_72
SV12IN_2X7I48_72
16 Jan 2013 01:07 - 16 Jan 2013 01:13 #28732
As far as I know with the distributed bitfiles, only ones with 7I48 in the
name are appropriate for use with the 7I48
Last edit: 16 Jan 2013 01:13 by PCW.
The following user(s) said Thank You: marsheng
16 Jan 2013 03:57 #28734
by marsheng
Thanks. We used the SV12_2X7I48_72 and it worked.
Next issue Limit switches ?? They work in the PNConfig but when I try and run I get a error. Tried inverting signals but still the same.
I have posted it under a previous discussion on it
http://www.linuxcnc.org/index.php/english/forum/49-basic-configuration/25796-joint-0-on-limit-switch?start=6#28722
