Motenc Card problem
16 Jan 2013 08:13 #28740
by GStewart
Motenc Card problem was created by GStewart
Hello,
I am trying to build another LinuxCNC system (currently running 4 machines on LinuxCNC) and I ran into a problem with version 2.5.
I am not sure if the card is not being recognized or if there is some other problem.
I even tried pulling a Motenc card from a running machine to verify that I don't have a bad card.
Glenn
Here is the error log;
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/toshiba-bmc6/linuxcnc/configs/motenc'
Machine configuration file is 'motenc.ini'
INIFILE=/home/toshiba-bmc6/linuxcnc/configs/motenc/motenc.ini
PARAMETER_FILE=motenc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=1668
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hal_motenc.ko': -1 No such device
motenc_motion.hal:4: exit value: 1
motenc_motion.hal:4: insmod failed, returned -1
See the output of 'dmesg' for more information.
1668
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 26.904399] I-pipe: Domain RTAI registered.
[ 26.904404] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 26.904405] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 26.904433] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 26.904434] PIPELINE layers:
[ 26.904436] f8443e20 9ac15d93 RTAI 200
[ 26.904438] c085cb20 0 Linux 100
[ 26.917134] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 26.917212] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 26.917216] RTAI[sched]: hard timer type/freq = APIC/6268378(Hz); default timing: periodic; linear timed lists.
[ 26.917218] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2608076000 hz.
[ 26.917220] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 26.917260] RTAI[usi]: enabled.
[ 26.947372] RTAI[math]: loaded.
[ 27.068959] MOTENC: ERROR, unknown card detected
[ 27.514020] RTAI[math]: unloaded.
[ 27.533016] SCHED releases registered named ALIEN RTGLBH
[ 27.567059] RTAI[malloc]: unloaded.
[ 27.662758] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 27.664172] I-pipe: Domain RTAI unregistered.
[ 27.664209] RTAI[hal]: unmounted.
Glenn
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=halui
DISPLAY=axis
Cleanup done
1668
16 Jan 2013 10:30 - 16 Jan 2013 10:31 #28743
Replied by PCW on topic Motenc Card problem
Is the motherboard the same as the other system that recognize the Motenc card? i
this error _may_ indicate a PCI bus issue.
An easy way to check is boot from the 2.5 live CD on system thats known to work with the Motenc card.
Last edit: 16 Jan 2013 10:31 by PCW.
16 Jan 2013 11:57 #28745
by GStewart
Replied by GStewart on topic Motenc Card problem
This is the problem. I decided to try another box while I was waiting for a response and everything is working now on an old computer.
The I3-3220 3.3Ghz processor and Asus P8h77-VLE motherboard does not seem to work with LinuxCNC and Motenc.
Thanks for the help.
