Disable jog in joint mode. SOLVED
19 Jan 2013 00:54 - 20 Jan 2013 14:57 #28805
by Miselph
Disable jog in joint mode. SOLVED was created by Miselph
Hi Folks,
I have a gantry based machine that is running nicely, EXCEPT that sometimes it drops back from axis (world?) to joint mode when you try and jog. At this point, if I have the X axis selected, it just moves one of my motors and racks the gantry. This could potentially be disastrous as it could lead to me damaging the gantry. So what I need it either a way of disabling jog in joint mode or preventing it from entering joint mode once the machine is homed.
Ideas please?
Ideas please?
Last edit: 20 Jan 2013 14:57 by Miselph.
19 Jan 2013 21:17 #28825
by ArcEye
Replied by ArcEye on topic Disable jog in joint mode.
Hi
If you insert a single line into /usr/bin/axis (save a copy first) you can prevent jogging in joints mode
From line 2688 (approx)
This will prevent jog working in joints mode
Obviously as with any edit, it will be lost when Linuxcnc is next upgraded.
Test this carefully to make sure it does exactly what you want on your machine, I just did it in the gantry sim
def jog(*args):
if not manual_ok(): return
if not manual_tab_visible(): return
#insert the below line
if joints_mode(): return
ensure_mode(linuxcnc.MODE_MANUAL)
c.jog(*args)
19 Jan 2013 23:53 #28829
by ArcEye
This is a improved solution, because it allows jogging in either mode until homed
def jog(*args):
isHomed=True
for i,h in enumerate(s.homed):
if s.axis_mask & (1<<i):
isHomed=isHomed and h
if joints_mode() and isHomed : return
c.jog(*args)
The following user(s) said Thank You: Miselph
20 Jan 2013 14:56 #28856
by Miselph
Replied by Miselph on topic Disable jog in joint mode.
Thank you, ArcEye. Problem solved!
Time to create page: 0.230 seconds
