Synchronizing Dual Motors (X & A)
04 Feb 2013 02:16 #29526
by manichols
Synchronizing Dual Motors (X & A) was created by manichols
Hello.. I have built a CNC which uses dual screw drives for the X axis. I understand that I can control both motors at the same time by setting the pins for the A motor (pins 8 & 9) to "Y Step" and "Y Direction"; however, this will always send identical signals to both motors. That's great if these motors always stay in synchronization. That's not going to happen in the real world. Mach3 allows for separate homing switches for the X and A axes even when the A axis is "slaved" to the X axis. This allows software to individually adjust the relative position of the motors to prevent "racking" of the gantry.
So, my question is whether or not there is a way to accomplish the same thing in LinuxCNC. I can't seem to find a way to do this; however, I am a 'newbie' to the CNC world and possibly overlooking the obvious. I have searched this and other forums and the internet looking for an answer but to no avail. I WANT TO USE LINUXCNC......
I would appreciate some assistance with this dilemma.
Thank You..
Mark
Thank You..
Mark
04 Feb 2013 05:07 - 04 Feb 2013 05:13 #29530
by alan_3301
Replied by alan_3301 on topic Synchronizing Dual Motors (X & A)
Do a search for gantrykins. Search on this forum and on google for info.
I had planned on getting this set up on my machine, but I found I have no need for it. 2 easy other ways around it.
If your motors are matched to your drivers and machine, and you are not trying to get too much out of them, they arent going to lose sync.
Also, even if it is racked a little, you can adjust the rotation of XY to compensate with 1 line of code.
G10 L2 P0 R1
the number after "R" is the angle of rotation. eg 1degree clockwise in example.
On my machine with rack&pinion, i aligned to endstops square with the gantry.
Before I power up, i run the gantry to the end by hand, then power on.
G10 L2 P0 R1
Last edit: 04 Feb 2013 05:13 by alan_3301.
04 Feb 2013 12:07 #29548
by manichols
Replied by manichols on topic Synchronizing Dual Motors (X & A)
I meant Y and A .. not X and A.. duh!
04 Feb 2013 17:45 #29553
by ArcEye
Replied by ArcEye on topic Synchronizing Dual Motors (X & A)
Hi
See /usr/share/doc/linuxcnc/examples/sample-configs/gantry for example set up
Run man gantrykins in a terminal for info on how the module works
Time to create page: 0.209 seconds
