joint following error on a-axis in simulator
06 Feb 2013 15:52 - 06 Feb 2013 15:55 #29690
by SvenH
joint following error on a-axis in simulator was created by SvenH
Hi Folks,
I'm doing some pre production work on my simulator on the laptop and keep getting a joint 3 following error for the a- axis.
Is there something wrong here:
If I recall correctly I set this up using the 9axis simulator configuration, changing as little as possible.
I have tried reducing max velocity and max_acceleration, and changed ferror to 5 and min_ferror to 1 as I saw used in other simulator ini files.
[AXIS_3]
TYPE = ANGULAR
HOME = 0.0
MAX_VELOCITY = 900.0
MAX_ACCELERATION = 1200.0
BACKLASH = 0.000
INPUT_SCALE = 40
OUTPUT_SCALE = 1.000
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0.0
HOME_LATCH_VEL = 0.0
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
HOME_SEQUENCE = 0
# WRAPPED_ROTARY = 0
Last edit: 06 Feb 2013 15:55 by SvenH.
06 Feb 2013 17:57 - 06 Feb 2013 17:57 #29695
by ArcEye
Replied by ArcEye on topic joint following error on a-axis in simulator
Hi
I assume that you are working in mm, being from Netherlands?
Does a max velocity of 54,000mm/min seem feasible to you on your machine?
Or acceleration of 1200mm/sec/sec?
Both seem hugely high.
My rotary axis on my lathe is set FERROR = 1, MIN_FERROR=0.25 with much lower velocity and acceleration.
I am sure that in the contrast lies your answer
Last edit: 06 Feb 2013 17:57 by ArcEye.
06 Feb 2013 23:09 #29710
by ArcEye
PS
Had a quick hunch and checked and sure enough,
FERROR = 0.05
MIN_FERROR = 0.01
are the figures from an imperial sim.ini file
Multiply them by 25 and you are not far from the figures I quoted
FERROR = 0.05
MIN_FERROR = 0.01
07 Feb 2013 15:25 #29753
by SvenH
Replied by SvenH on topic joint following error on a-axis in simulator
Ah, so the FERROR and MIN_FERROR figures are dimension based? That is good to know, did not read that anywhere (or just did not pick that up)
But should these numbers actually matter in the simulator? And in a rotational axis?
I also copied the numbers from my actual machine, that also gave the following error.
I'll play around a bit and see if there are thanges
07 Feb 2013 21:13 #29762
by ArcEye
All the relevant values are based upon the units set in the .ini file (LINEAR_UNITS= ANGULAR_UNITS= )
If you still get errors, attach your full configs in a zip, so that we can try to get them to work
Time to create page: 0.470 seconds
