No movement, zero nada zilch on all axes - SOLVED
12 Feb 2013 08:53 - 12 Feb 2013 23:37 #29928
by mekhanic7
No movement, zero nada zilch on all axes - SOLVED was created by mekhanic7
I have converted a liquid dispensing machine to steppers and cannot get any movement.
I can jog on screen, run g code on screen etc but no actual movement.
My e-stop switch works fine tru the breakout board.
The steppers power up and hold but no movement.
setup:
Parker OEM650 drives
Kelling nema 23 steppers
C10 breakout board
Dell 3ghz comp, 1.5gig RAM, built in parralell port
Not sure where to begin with trouble shooting...
setup:
C10 breakout board
Last edit: 12 Feb 2013 23:37 by mekhanic7.
12 Feb 2013 17:32 #29935
by Rick G
Replied by Rick G on topic No movement, zero nada zilch on all axes
Not really enough information there but to start...
Make sure you have the correct parallel port address and that the port is working.
Check to make sure the signals are getting to your drives. (you can check direction pins with a voltmeter.)
Check to make sure you have your direction and step pins correct in your config.
Does your system use a charge pump?
Rick G
Rick G
12 Feb 2013 20:50 #29945
by BigJohnT
Replied by BigJohnT on topic No movement, zero nada zilch on all axes
Do you have your C10 board setup correctly to match the drives and enabled?
12 Feb 2013 23:41 - 12 Feb 2013 23:43 #29959
by mekhanic7
Replied by mekhanic7 on topic No movement, zero nada zilch on all axes
I checked for signal thru the BOB and was getting voltage. I then pulled apart the drives and the actual drives were not enabled internally via jumpers. I got motion!
Thanks for the help!
Last edit: 12 Feb 2013 23:43 by mekhanic7.
13 Feb 2013 00:37 #29964
by BigJohnT
Awesome!
13 Feb 2013 18:08 #30009
by Rick G
Glad to hear it!.
Rick G
Rick G
Time to create page: 0.103 seconds
