Elefu setup?
18 Feb 2013 01:30 #30220
by Alexncus
Elefu setup? was created by Alexncus
Newbie. Successfully installed linuxcnc on PC. Trying to config parport for USB connection to drive new elefu board. Anyone have pointers or experience with elefu board?
18 Feb 2013 01:58 #30222
by cncbasher
you can't .. Linuxcnc does not support USB ..
nor can you use a Parrellport to USB convertor .
Replied by cncbasher on topic Elefu setup?
The following user(s) said Thank You: Alexncus
18 Feb 2013 04:39 - 18 Feb 2013 04:40 #30226
by Alexncus
Replied by Alexncus on topic Elefu setup?
Ugh. If not LinuxCNC, any comparable / alternative Linux CNC controllers that work with USB to build a CNC mill?
Last edit: 18 Feb 2013 04:40 by Alexncus.
25 Feb 2013 02:26 #30530
Mach3 seems to use USB, so may be an option. Currently only on Windows, but they have announced the intention of a Linux version.
What does the Elefu board do? It seems to incorporate an Atmega, so I am not clear if it needs any external CNC controller.
Replied by andypugh on topic Elefu setup?
Time to create page: 0.303 seconds
