installation
22 Feb 2013 19:56 #30446
by charrier
installation was created by charrier
i just install on a new computeur linux cnc on hardy 8.04 whith cd live
i join the error when i open linuxcnc
what is the problem
the latency test is ok my latency max jitter is 16500 ns
rv
what is the problem
rv
22 Feb 2013 20:09 - 22 Feb 2013 20:10 #30448
by ArcEye
Replied by ArcEye on topic installation
Hi
You need to post the error print out, run linuxcnc from a terminal and cut and paste the error output to a .txt file
Immediately afterwards run cat /var/log/dmesg > dmesg.txt and attach that too
Last edit: 22 Feb 2013 20:10 by ArcEye.
Time to create page: 0.170 seconds
