G0 velocity limitation
In the ini_config.html linked above, MAX_LINEAR_VELOCITY is in [DISPLAY]
In the axis.ini defualt from the livecd MAX_LINEAR_VELOCITY is in [DISPLAY] and [TRAJ]
All throughout this thread it is said to be in [TRAJ].
Maybe in [TRAJ] it is ignored?
I noticed that and tried moving it from [TRAJ] to [DISPLAY] (in the inch.ini file). And the result was that that it needs to be in the [TRAJ] section in order to control what appears in the max velocity slider in the Axis screen.
jensor
Note
The following [DISPLAY] items are for the AXIS interface only.
DEFAULT_LINEAR_VELOCITY = .25 - The default velocity for linear jogs, in , machine units per second.
MIN_VELOCITY = .01 - The approximate lowest value the jog slider.
MAX_LINEAR_VELOCITY = 1.0 - The maximum velocity for linear jogs, in machine units per second.
MIN_LINEAR_VELOCITY = .01 - The approximate lowest value the jog slider.
DEFAULT_ANGULAR_VELOCITY = .25 - The default velocity for angular jogs, in machine units per second.
MIN_ANGULAR_VELOCITY = .01 - The approximate lowest value the jog slider.
MAX_ANGULAR_VELOCITY = 1.0 - The maximum velocity for angular jogs, in machine units per second.
Rick G
I think you are right and this is a documentation bug. That setting needs to be in [TRAJ].
