Move Tool Change Location?
- javabandit
02 Mar 2013 05:18 #30743
by javabandit
Move Tool Change Location? was created by javabandit
Hi Everyone! I'm new to CNC machining, and I'm stuck on a problem with my new lathe.
Smithy 1315 Lathe
with a Mesa 5i20 controller (I think)
Running LinuxCNC on the Ubuntu system that came with the lathe.
I wrote the code for my first part, which requires a tool change. I'm using T1 and T3 in the turret. Everything works fine with it. My concern right now is to speed up the cycle time. Right now, when I issue the tool change command (Tn M6 G43) the machine will move all the way to the machine origin (G54) before turning the turret. It's a long way from my part, and a lot of unnecessary movement.
How can I make my tool change happen closer to the part?
Smithy 1315 Lathe
02 Mar 2013 05:57 #30746
by cradek
Replied by cradek on topic Move Tool Change Location?
www.linuxcnc.org/docs/html/config/ini_co..._sub_emcio_section_a
Check out TOOL_CHANGE_AT_G30
With this option, you can set the tool change location for your job by moving the machine where you want it and issuing G30.1
- javabandit
02 Mar 2013 07:03 #30747
by javabandit
Replied by javabandit on topic Move Tool Change Location?
Thank you, thank you! That did it!
