MaxNC 10/15
22 Mar 2013 07:59 #31704 by earendall
MaxNC 10/15 was created by earendall
I found some settings files that some one else had configured and when I try to run them this is the errors I get I have also attached a zip file of the settings files that I was using.
I might have left something out, if I did, please ask away.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/MaxNC 15 OL'
Machine configuration file is 'maxnc10ol.ini'
INIFILE=/home/linuxcnc/linuxcnc/configs/MaxNC 15 OL/maxnc10ol.ini
PARAMETER_FILE=emc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
libnml/buffer/physmem.cc 143: PHYSMEM_HANDLE: Can't write 11592 bytes at offset 60 from buffer of size 10208.
libnml/cms/cms_in.cc 1373: CMS:(emcStatus) Error writing 11592 bytes to global memory at offset 0x9074d20
(See libnml/cms/cms_in.cc line 1376.)
* Current Directory = /home/linuxcnc/linuxcnc/configs/MaxNC 15 OL
* BufferName = emcStatus
* BufferType = 0
* ProcessName = emc
* Configuration File = emc.nml
* CMS Status = -3 (CMS_INTERNAL_ACCESS_ERROR: An error occured during an internal access function. )
* Recent errors repeated:
(See libnml/cms/cm
* BufferLine: B emcStatus SHMEM localhost 10240 0 0 2 16 1002 TCP=5005 xdr
* ProcessLine: P emc emcStatus LOCAL localhost W 0 1.0 0 0
* error_type = 5 (NML_INTERNAL_CMS_ERROR)
Maximum number of errors to print exceeded!
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Killing task linuxcncsvr, PID=2058
Killing task milltask, PID=2174
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
2058
PID TTY STAT TIME COMMAND
2174
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 775.481118] I-pipe: Domain RTAI registered.
[ 775.481131] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 775.481135] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 775.481145] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 775.481148] PIPELINE layers:
[ 775.481153] df6afe20 9ac15d93 RTAI 200
[ 775.481157] c085cb20 0 Linux 100
[ 775.512915] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 775.513235] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 775.513243] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: periodic; linear timed lists.
[ 775.513248] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1200138000 hz.
[ 775.513252] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 775.513432] RTAI[usi]: enabled.
[ 775.560941] RTAI[math]: loaded.
[ 775.959343] config string '0x0378'
[ 783.339344] RTAI[math]: unloaded.
[ 783.443961] SCHED releases registered named ALIEN RTGLBH
[ 783.456416] RTAI[malloc]: unloaded.
[ 783.556025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 783.561731] I-pipe: Domain RTAI unregistered.
[ 783.561747] RTAI[hal]: unmounted.
22 Mar 2013 17:12 #31717 by cncbasher
Replied by cncbasher on topic MaxNC 10/15
this is a very old emc config , you would be better using stepconf and regenerate a new configuration
have you the parrell port pinout connection information ?
22 Mar 2013 19:24 #31723 by earendall
Replied by earendall on topic MaxNC 10/15
I do have the connection information. I'm not sure what settings to use on the first drive page in stepconf. are there any generic setting to start with?
Thanks!
22 Mar 2013 22:53 #31728 by BigJohnT
Replied by BigJohnT on topic MaxNC 10/15
Sherline should be safe, What drives do you have?
22 Mar 2013 23:05 #31730 by earendall
The driver board is their custom board and the steppers are Powermax from kollmorgen.
I believe their board uses a CW/CCW pulse for control Vs the Pulse/DIR setup.
22 Mar 2013 23:22 #31732 by BigJohnT
After creating your config in Stepconf you will have to change the step type and not open the config up in Stepconf again.
www.linuxcnc.org/docs/html/man/man9/stepgen.9.html
The following user(s) said Thank You: earendall
22 Mar 2013 23:26 - 22 Mar 2013 23:35 #31733 by BigJohnT
Or you could just remove the inifile line NML_FILE = emc.nml and your config should run.
Edit: I just tested your configuration after removing the offending line and it works for me... That computer has been buried all week and just now got access to it.
Last edit: 22 Mar 2013 23:35 by BigJohnT.
23 Mar 2013 00:46 #31735 by earendall
I will give that a try this weekend. Thanks for the assistance.
I will report my findings.
23 Mar 2013 02:36 #31739 by earendall
Out of curiosity, what does the NML file do?
If I can run the linuxcnc without it I assume its not really needed?
23 Mar 2013 05:34 #31747 by BigJohnT
I'm not sure what the nml file does but I assume it sets some options for the nml messaging.
It is needed but after 2.3 the installed version is used because it changed. So if you try to run a config from 2.3 in 2.4 or 2.5 you will get an error unless you modify the nml file to the 2.4/2.5 requirements.
Time to create page: 0.384 seconds
