Stepconf?
03 Apr 2013 18:59 #32211
by drmacro
I've been tinkering with the .ini & .hal files and am a bit confused.
What actually determines the pulse width of the step output?
It appears to be some combination of entries in these two files, but it's not clear to me from the docs or the examples I've seen so far.
Regards,
Mac
Regards,
Mac
03 Apr 2013 19:41 - 03 Apr 2013 19:42 #32215
by drmacro
Yes I've read that and am still waiting for the light to shine.
If I want a steplen of 90us and a stepspace of 50us, how do I define that.
Apparently how often make_pulses() is called makes the actual pulses. But, what determines it's call rate? BASE_PERIOD?
setp stepgen.x.steplen is set to 1 in most examples I see. Is this 1 x times the make_pulses rate?
Last edit: 03 Apr 2013 19:42 by drmacro.
04 Apr 2013 23:44 #32280
by drmacro
Turns out there is a great write up on the subject here:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Tweaki...ftwareStepGeneration
Time to create page: 0.186 seconds
