Configuring inputs in EMC
14 Apr 2013 00:57 #32694
by m8298
Configuring inputs in EMC was created by m8298
Hello, I am somewhat new to EMC. I have a 4 axis router mill that is already set up in Mach3. I am setting it up with EMC also to do a comparison, and I am a little confused on how to setup the inputs. I have home/limit switches set up on axes X, Y, and Z. All switches are active high. All three home and negative limits are common on pin 12, and all three positive limits are common on pin 11. I have a probe on pin 13 and an estop on pin 10. How is this done in EMC?
14 Apr 2013 03:31 #32708
by Rick G
Replied by Rick G on topic Configuring inputs in EMC
14 Apr 2013 03:43 #32709
by m8298
Replied by m8298 on topic Configuring inputs in EMC
I have seen that. What I need to know is how to edit the hal and/or INI file to reflect my inputs?
14 Apr 2013 04:30 #32715
by m8298
This is what I have tried:
net XYZ-home parport.0.pin-12-in-not => axis.0.neg-lim-sw-in axis.1.neg-lim-sw-in axis.2.neg-lim-sw-in
net XYZ-max-lim parport.0.pin-11-in-not => axis.0.pos-lim-sw-in axis.1.pos-lim-sw-in axis.2.pos-lim-sw-in
Then I get:
Joint 0 on limit switch error
Joint 1 on limit switch error
Joint 2 on limit switch error
What am I doing wrong???
Then I get:
14 Apr 2013 06:23 #32717
by m8298
NEVERMIND. I got it working.
15 Apr 2013 18:57 #32742
Was the problem using the in-not rather than in pins?
Replied by andypugh on topic Configuring inputs in EMC
Good.NEVERMIND. I got it working.
15 Apr 2013 19:25 #32745
by m8298
That was one part of the problem. The other part of the problem was that I hadn't set up my INI file with the parameters (HOME_SEARCH_VEL, HOME_LATCH_VEL, etc.) I get ahead of myself sometimes.
Time to create page: 0.246 seconds
