Basic Configuration
15 Apr 2013 22:39 #32754
by malgazz
Basic Configuration was created by malgazz
Hi
I am new to cnc and to EMC2.I would like to know which profile to choose when setting up.
I have a home built router the table size is 1500mm x 1500mm with a working area of 1200mm x 1200mm.It is a gantry unit, the Xaxis drives the gantry with 2 motors (one either side of gantry)
X&Y are rack and pinion, the Z is screw driven.
The Z has a direct drive to the screw
The X and Y have a 1.5 module rack with an 18 tooth pinion, the pinion is coupled to a 60 tooth gear and the motors have a 20 tooth gear.
The electronics is one of those dreaded blue TB6560 4 axis boards.
Regards
Gazza
Regards
Gazza
15 Apr 2013 22:53 - 15 Apr 2013 22:54 #32756
by BigJohnT
Replied by BigJohnT on topic Basic Configuration
You can either use the Stepconf Wizard to generate your config or use the
6560 sample configuration
and modify it.
Last edit: 15 Apr 2013 22:54 by BigJohnT.
15 Apr 2013 22:57 - 15 Apr 2013 23:21 #32757
by malgazz
Replied by malgazz on topic Basic Configuration
Hi John
Ok I got it and the link .
The PC copled to the router, does not have a link to the web, so its back and forth between this pc and the garage.
Downloaded the TB6560.tar.gz.
Will give it a go
Tks
Gary
Will give it a go
Tks
Gary
Last edit: 15 Apr 2013 23:21 by malgazz.
