Spindle control for a 2nd spindle
26 Apr 2013 07:22 #33221
loadrt pwmgen output_type=0
change it to say
Then duplicate all the pwmgen.0 HAL lines for pwmgen.1
Replied by andypugh on topic Spindle control for a 2nd spindle
If you look in your HAL file you will seeHow can I create a second PWM generator and link it that I can use both?
change it to say
26 Apr 2013 10:35 #33225
by arvidb
I'm guessing a bit now, but I think Andy meant
"change it to say
loadrt pwmgen output_type=0,0"
which should give you another pwmgen (called "pwmgen.1"). The "0,0" means create two pwmgens of type 0.
All this from the manual only, I haven't tested it myself:
linuxcnc.org/docs/html/man/man9/stepgen.9.html
Replied by arvidb on topic Spindle control for a 2nd spindle
change it to say
"change it to say
The following user(s) said Thank You: mmt
26 Apr 2013 22:34 #33250
by mmt
Replied by mmt on topic Spindle control for a 2nd spindle
arvidb was correct Andy. It was 0,0 and then pwmgen.1 worked.
Thank you both for your help.
Time to create page: 0.072 seconds
