Spindle On/Off setup?
15 May 2013 00:51 #34090
by cotang
Spindle On/Off setup? was created by cotang
Hello,
I did a quick search but didn't really come up with anything exact. I was wondering how I can turn on/off the spindle via gcode? I currently have a gecko drive (g540) with one of the output (pin 5) connected to the run input of the SuperPID. This is a known configuration from SuperPID so it should work. The question is setting it up on linuxcnc.
Under the configuration wizard of linuxcnc where I setup the parallel port, I used one of the pin (I think pin 17.... not sure) I set this to "Spindle On". The question is, which g-code will turn on that pin. M3 and M4 is used as CW and CCW on the spindle and M5 is to stop the spindle. Which G-code is for "Spindle On"?
Also if using M5 command, does that turn off the M3 and M4 if they are setup to be used?
15 May 2013 06:10 #34101
by BigJohnT
Replied by BigJohnT on topic Spindle On/Off setup?
M3 is CW and M4 is CCW and M5 is Spindle Off, if you have a spindle speed set with S when you issue a M3 or M4 the spindle will start. Did you look at the examples in the Integrator Manual?
JT
JT
Time to create page: 0.098 seconds
