Spindle true RPM..... HELP PLEASE!!!
18 May 2013 22:14 - 18 May 2013 22:22 #34333
by dovidu
Spindle true RPM..... HELP PLEASE!!! was created by dovidu
Hello everyone! Currently I am working on my cnc lathe project (sherline lathe converted to CNC)
Having frustrations with MACH3, I ditched the disgusting windows along with it and formatted my entire computer. Simply, I accepted the genius of Linux system !!
Well, so far through my venture, I have accomplished the following:
1. make x, z axis work
2. make x, z homing and limits work
3. make the VFD work via PWM
However, I can't seem to get true RPM speed displayed....
I use an inductive proximity sensor for spindle index, which senses 1 pulse per revolution.
I have set the spindle index on pin 4 of my gecko g540 drive, which sends signals to pin 14 of DB25. I have properly set this up through stepconf wizard.
When I turn the spindle on, I can see the signals with HAL scope.
The problem is, the DRO for spindle speed does not show a true spindle speed, but rather, it is fixed (for example, when I raise the RPM to 100, 200, 300, 400...... , the DRO reads the same as I commanded, not the real RPM).
When I raise the RPM on EMC, I can see my spindle speed increasing, but sadly, the dro for spindle speed does not represent the actual rpm speed of the spindle.
How can I make the rpm dro corespond with actual rpm speed?.....
any input is appreciated!! <3
oh, and also, is "spindle index" same as "spindle encoder"...?
Last edit: 18 May 2013 22:22 by dovidu.
18 May 2013 23:43 #34337
by ArcEye
Replied by ArcEye on topic Spindle true RPM..... HELP PLEASE!!!
You will need to zip your config folder and attach it to a post.
We are just guessing otherwise.
The following user(s) said Thank You: dovidu
19 May 2013 00:29 #34340
by dovidu
Replied by dovidu on topic Spindle true RPM..... HELP PLEASE!!!
I see,
I have attached my config folder!
19 May 2013 01:36 #34342
Replied by cmorley on topic Spindle true RPM..... HELP PLEASE!!!
To get the true spindle rpm displayed using stepconf,
You must select a' spindle phase a' in the parallel port screen (and of course the spindle display option)
What is not so clear to me is if you also need an index input.
But even at that if you build a sample config and look at the HAL files you'll see how it's done.
(most of the code is in the custom_postgui.hal file.)
Chris M
Chris M
19 May 2013 01:53 #34345
by cncbasher
Replied by cncbasher on topic Spindle true RPM..... HELP PLEASE!!!
add the following lines to your hal file
setp encoder.0.position-scale 50.000000
setp encoder.0.counter-mode 1
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-velocity encoder.0.velocity => motion.spindle-speed-in
net spindle-index-enable encoder.0.index-enable <=> motion.spindle-index-enable
net spindle-phase-a encoder.0.phase-A
net spindle-phase-b encoder.0.phase-B
net spindle-index encoder.0.phase-Z
position scale value will need to be changed to suit your encoder count
19 May 2013 16:39 #34378
by ArcEye
Afraid your zip appears to be corrupt, I can't find anything in it except what looks like an orphaned symlink
If the previous answers did not solve it you will have to re post your config
Time to create page: 0.075 seconds
