Need to decode what this means.... :(
18 May 2013 23:02 #34334
by dovidu
Need to decode what this means.... :( was created by dovidu
Having been a mach3 and windows user, I do not under stand this ....... ![:blink: :blink:](/media/kunena/emoticons/blink.png)
Re: Spindle RPM? How to display?
On 11/08/2012 01:56 PM, Mark Brown wrote:
> Hi all,
> Is there something in the .ini file that will enable the spindle speed to
> display on EMC2 for my mill?
Do you have an encoder on the spindle? If so, see
pico-systems.com/codes/jebport/
files are spindle.hal and spindle.xml
and yyou need to call up these files from the .ini file
as a POSTGUI_HALFILE as shown in the .ini file there.
The spindle speed is calculated in ppmc_motion.hal
and put on a HAL pin so the spindle.hal file can put
it into the bar graph provided by spindle.xml
Jon
any input is appreciated!!
> Hi all,
Jon
18 May 2013 23:41 #34336
by ArcEye
Replied by ArcEye on topic Need to decode what this means.... :(
Hi
Copy the spindle.xml file and the spindle.hal files into your config folder.
Open your .ini file in gedit and in the [DISPLAY] section have
PYVCP = spindle.xml
In the [HAL] section have
POSTGUI_HALFILE = spindle.hal
Save the file and restart your config and the spindle speed bar should display ( so long as your other connections are the same as Jons setup)
PYVCP = spindle.xml
The following user(s) said Thank You: dovidu
19 May 2013 00:24 #34339
by dovidu
Replied by dovidu on topic Need to decode what this means.... :(
thank you for the input!
I have followed what you instructed.
i put the spindle.xlm and spindle.hal files to the config folder(the one that was created by stepconf wizard, where my .ini file is, right??)
i have also edited the .ini file
one thing to note was that there are two types of spindle.hal : net and link? the name was same but the icons are different
anyways, when I try to load EMC, I get this error (in the attached)
19 May 2013 07:17 #34366
Replied by andypugh on topic Need to decode what this means.... :(
There is something unexplained wrong with the spindle.xml file.
Screen shots tend to miss things.
If you open a terminal window and start LinuxCNC by just typing
linuxcnc
Then after it crashes there will be a lot of text in the window that you can copy and paste into a message. That is a lot easier to interpret.
linuxcnc
19 May 2013 16:50 #34380
by ArcEye
What is wrong are the three dashes (-) in front of tags, they should not be there
Remove and it should load OK
-<pyvcp>
-<label>
<text>"Spindle Speed:"</text>
</label>
-<bar>
<halpin>"SpindleRPM"</halpin>
<max_>5000</max_>
</bar>
</pyvcp>
Time to create page: 0.096 seconds
