maximum speed and maximun jog
23 May 2013 23:57 #34597
by charrier
maximum speed and maximun jog was created by charrier
I try to adjust my ini file and hal file and axis for the better way,
i would like to limit the jog speed and speed max on axix because when i move a lot , my motor loose step.
and my future work.
i try to limit in ini for each axis, but the result is not well
in the actual the speed is 1500mm/minute my motor can run under 600 or 700 mm/minute, and i the same thing for jog speed.
The value are fixed perhaps, i don't know.??
thanks for a solution
rv
and my future work.
rv
- captain chaos
- Thank you received: 3
24 May 2013 14:03 #34628
by captain chaos
Replied by captain chaos on topic maximum speed and maximun jog
Hi charrier,
Rread the [TRAJ] and [AXIS_#] section of the "Integrator Manual" to get a little understanding on accelerations and velocities, look at FERROR and MIN_FERROR as well in [AXIS].
Also could you post your INI file and Hal file for us to look at, so we can get a better Idea of your problem?
28 May 2013 00:35 #34767
by charrier
Replied by charrier on topic maximum speed and maximun jog
thanks for your reponse finaly i find
i modify velocity an other number
Time to create page: 0.551 seconds
