interpolated/Indipendent axis
25 May 2013 13:40 #34664
by ioiotutu
interpolated/Indipendent axis was created by ioiotutu
I have to build a 4 axis milling machine, standard XYZS with rotary axis A mounted in X direction. I need to work on cilinder (XZAS) or on the standard XY plane (XYZS). For this i understand how to do.
When i work on the cylinder with XZAS i need two working method:
1) standard interpolation, for example to write on the cylinder or make incision on it
2) lathe mode, i need to turn A axis like a spindle (indipendent axis) and use XZ to profile
Can i configure the machine in this way?
Can i swap A axis from indipendent/spindle to interpolated with M-code?
Thanks,
Michele
Thanks,
Michele
26 May 2013 05:56 #34704
I think so. Some of this might be useful:
www.linuxcnc.org/index.php/english/forum...stion?start=10#30946
That is about using a spindle as an axis, whereas you sound to want to use an axis as a spindle, but to the software it's all the same thing.
Replied by andypugh on topic interpolated/Indipendent axis
ICan i swap A axis from indipendent/spindle to interpolated with M-code?
The following user(s) said Thank You: ioiotutu
27 May 2013 16:05 #34747
by ioiotutu
Replied by ioiotutu on topic interpolated/Indipendent axis
Thanks,
i'll test it in the next days.
