pyvcp code of pom axex
28 May 2013 00:43 #34769
by charrier
pyvcp code of pom axex was created by charrier
i would like to know, just the code for make the zero (pom ) for x y and z axis.
this button exist on axis but i would like a bigest on the right of display.
i know now how to put new button on right .xml and .hal and mdi command
thanks
rv
thanks
rv
28 May 2013 03:58 #34792
by BigJohnT
Replied by BigJohnT on topic pyvcp code of pom axex
If I understand your question correctly look at G10 L20 in the user manual.
JT
JT
28 May 2013 23:33 - 29 May 2013 03:44 #34854
by charrier
Replied by charrier on topic pyvcp code of pom axex
Merci pour votre reponse JT
j'ai essayer mais ça ne fonctionne pas, "Pas de commande MDI avant la prise origine"
j'ai joint mon ecran que je veux faire,
sur la droite j'ai creer 3 boutons "POMx" POMY POMZ pour remplacer le petit de AXIS d'origine "pom des axes"
la solution g10l20 ne fonctionne pas.
une autre solution existe ????
I want to home each axis, With my new big button, Like the homing With the homing all of axis.
Sorry for this little no understanding
Merci d'avance pour vos reponses
Last edit: 29 May 2013 03:44 by charrier.
29 May 2013 01:29 - 29 May 2013 01:42 #34862
by BigJohnT
I don't understand what POM stands for. You will have to home before any MDI command will work.
Edit: Or set no force homing in the ini file...
JT
JT
Last edit: 29 May 2013 01:42 by BigJohnT.
Time to create page: 0.107 seconds
