Some advices for a noob
01 Jul 2013 15:11 #36187
by kenran
Some advices for a noob was created by kenran
Hello,
I have a motor (I think multiphase because it has plenty of torque even at low speed)
and its driver
I have the input :
- start
- brake
- CW / CCW
Which are controlled by relays connected to COM
Output:
24V pulses (12 per revolution)
My questions:
- How to use the motor via the driver (I have cards with relay)? Wich module ?
- Is Linuxcnc able to automatically calculate the displacement using the driver output pulses?
- The output pulses are 24V, how to connect them to a LPT input (optocoupler, transistor)
Thank you in advance
and its driver
I have the input :
- start
- brake
- CW / CCW
Output:
My questions:
01 Jul 2013 15:31 #36188
by cncbasher
Replied by cncbasher on topic Some advices for a noob
have you details of the driver , link to manual etc
01 Jul 2013 18:57 #36190
by kenran
Replied by kenran on topic Some advices for a noob
Here the driver manual.
Thank you for your time
01 Jul 2013 19:20 #36193
For speed control you probably need a PWM output from LinuxCNC
www.linuxcnc.org/docs/html/examples/spindle_fr.html
This circuit can be used to convert the PWM to an analogue voltage for your drive:
tom-itx.dyndns.org:81/~webpage/cnc/ACPL-P480_opto_sch.png
However that optocoupler:
radiospares-fr.rs-online.com/web/p/optoc...searchTerm=ACPL-P480
Is only rated to 20V. I didn't read the manual carefully enough to work out what the analogue control voltage was.
Replied by andypugh on topic Some advices for a noob
01 Jul 2013 19:48 #36194
by kenran
According to the manual the motor speed can be control by the driver (always the same speed) or by voltage but linearity between voltage and speed (to low voltage = not enough torque = stopped )
Is it really the best way to convert output impulse in voltage ? Is there enough accuracy ? Why not counting the pulse (like a mouse) ?
01 Jul 2013 22:43 #36198
Replied by PCW on topic Some advices for a noob
Speed control (Linuxcnc --> motor) looks to be analog (0 to 5V)
Good PWM --> ANALOG circuits can easily have better than 0.1% linearity
(much better than the drive probably) so this should not be an issue
The SPD output pulse is open collector, so can interface directly with a parallel port, by using a pullup resistor to 5V but you may want isolation between your PC and the drive so a breakout board may be advisable.
The following user(s) said Thank You: kenran
02 Jul 2013 00:38 #36205
by kenran
Ok for the input i can use an pwm -> analog converter like below ?
wiki.linuxcnc.org/cgi-bin/wiki.pl?action...tal/Analog_Interface
For the SP output which module / configuration may i use ? The motor speed is below 50 tr/min
02 Jul 2013 04:11 #36214
The one I posted a link to works better.
02 Jul 2013 04:41 #36219
The pulse can be counted with linuxCNCs encoder component,
Note that since the SP output is just a single pulse (not quadrature),
it cannot be used for accurate position information if the gearmotor reverses
as it may possibly gain/lose counts at reversals
02 Jul 2013 21:49 #36237
by kenran
Ok i've done Andy's PWM to analog interface but i don't get how to connect signals.
I want to move axis X using LPT and PWMGEN
Here my files :
# INI
[EMC]
MACHINE = chariot
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/tereo/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = chariot.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 50000
SERVO_PERIOD = 50000
[HAL]
HALFILE = chariot.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 1
COORDINATES = X
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.10
MAX_LINEAR_VELOCITY = 1.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 30.0
STEPGEN_MAXACCEL = 30.0
SCALE = 1.8
FERROR = 1.0
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 500.0
HOME_OFFSET = 0.0
and HAL file :
loadrt threads
# load parport driver
loadrt hal_parport cfg="0x378"
# connect parport to threads
# read input first
here i don't have servo_thread or base_thread only thread1
addf parport.0.read thread1 1
# write output last
addf parport.0.write thread1 -1
# connect physical pins to the signals
net Xstep => parport.0.pin-03-out
net Xdir => parport.0.pin-02-out
# create a signal for the estop loopback
#net estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in
# i have a pwm and a dir
loadrt pwmgen output_type=1
addf pwmgen.update thread1
addf pwmgen.make-pulses thread1
here how i connect pwmgen.0.value ,and pwmgen.0.pwm to parport.0.pin-09.out ?
setp pwmgen.0.pwm-freq 500.0
Here my files :
# INI
[EMC]
MACHINE = chariot
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 50000
[HAL]
[TRAJ]
AXES = 1
COORDINATES = X
LINEAR_UNITS = mm
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
SCALE = 1.8
FERROR = 1.0
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 500.0
HOME_OFFSET = 0.0
and HAL file :
loadrt threads
# read input first
# write output last
Time to create page: 0.114 seconds
