Paralell port questions
10 Jul 2013 05:51 #36473
by rmattioda
Paralell port questions was created by rmattioda
i would like to create a control panel and I already have an MPG2 using my second port.
can I add another port and wire it to a breakout board so that input signals could be used such as switches and such?
10 Jul 2013 05:56 #36474
Replied by PCW on topic Paralell port questions
Yes, you can basically add as many parallel ports as you have slots for
(I think 8 ports is the maximum)
10 Jul 2013 13:15 #36482
by emcPT
Replied by emcPT on topic Paralell port questions
10 Jul 2013 15:12 #36488
by ArcEye
Replied by ArcEye on topic Paralell port questions
Hi
The 9865 chip based card emcPT pointed to should work fine.
Just be aware that CNC4PC are very expensive, you can buy a similar card from Amazon for $9.95 and probably get one from ebay or newegg for $5
If PCI slots are at a premium, the dual headed twin port cards work well too
(also see www.linuxcnc.org/index.php/english/forum...-parallel-port-cards)
Time to create page: 0.087 seconds
