gprof with emc2 2.4.7
- yutingkao23
17 Jul 2013 15:11 #36735
by yutingkao23
gprof with emc2 2.4.7 was created by yutingkao23
I try this document to enable gprof profiling, and i already got data.
But I only got callgraph and call path, the execution time does not show out. Does anybody know what does it happen ?
Thanks.
Thanks.
17 Jul 2013 16:03 - 17 Jul 2013 18:53 #36739
by ArcEye
Replied by ArcEye on topic gprof with emc2 2.4.7
We have no idea what you are doing, so hard to say.
It is unlikely to work with anything other than a userspace program which exits normally according to the docs
In order to write the `gmon.out' file properly, your program must exit normally: by returning from main or by calling exit.
Last edit: 17 Jul 2013 18:53 by ArcEye.
The following user(s) said Thank You: yutingkao23
- yutingkao23
21 Jul 2013 01:47 #36839
by yutingkao23
Replied by yutingkao23 on topic gprof with emc2 2.4.7
I just want to profile emc execution time and cycle, and especially emctask, gui, motion .... and so on.
Right now, I got some execution callgraph, but the execution time has some problems.
21 Jul 2013 16:51 #36855
by ArcEye
AFAIK you need to have a kernel built with readprofile support to be able to profile kernel modules
Since a lot of Linuxcnc comprises of realtime kernel modules, I don't know how much you are going to be able to do with gprof alone.
The more I read about gprof, the less it appears to be useful for much![:P :P](/media/kunena/emoticons/tongue.png)
- yutingkao23
23 Jul 2013 23:30 #36948
by yutingkao23
Thanks for your help !
I think gprof is a view of compiler level, and compiler level is hard to profile linux kernel.
So, I think I should try different profiling view, such as Lttng (system wide).
BTW, oprofile is not support realtime module. When I start oprofile, it crush immediately.
Time to create page: 0.070 seconds
