Configuring Plasma table with THC
27 Jul 2013 13:34 - 27 Jul 2013 13:34 #37090
by bdrotaru
Configuring Plasma table with THC was created by bdrotaru
Hi.
Please hel me to configure plasma table with 3 axis in following port configuration (only 1 paralel port is used: 378)
Outputs:
X dir 2
X step 3
Y dir 4
Y step 5
Z dir 6
Z step 7
Enable motors: 1
Relay: 14
Inputs:
XYZ Homming 15 (I will use G28.1)
Probe: 15
THC On: 12
THC Up: 10
THC Down: 11
ESTOP 13
My linux knowledge is 0 so please help me.
Thank You
Outputs:
X dir 2
X step 3
Y dir 4
Y step 5
Z dir 6
Z step 7
Enable motors: 1
Relay: 14
Inputs:
Probe: 15
THC On: 12
THC Up: 10
THC Down: 11
ESTOP 13
Thank You
Last edit: 27 Jul 2013 13:34 by bdrotaru.
27 Jul 2013 22:04 #37097
by BigJohnT
Replied by BigJohnT on topic Configuring Plasma table with THC
Use the Stepconf Wizard to generate you configuration. You will also need to know how many steps per user unit (inch or mm) and the step timings your drives like.
JT
JT
28 Jul 2013 02:21 #37101
by bdrotaru
Replied by bdrotaru on topic Configuring Plasma table with THC
I know how to config motors.
I don't know how to integrate THC signals in EMC
28 Jul 2013 03:14 #37104
by BigJohnT
Time to create page: 0.069 seconds
