Randomly appearing "joint 0 on limit switch error"
28 Jul 2013 20:30 #37160
by Hodor
Randomly appearing "joint 0 on limit switch error" was created by Hodor
Hi there
now 2 Weeks have passed and i milled several example and test files. So far everything is well: I can home the machine and mill.
BUT:
Sometimes when it's milling, there appears a joint 0 on limit switch error.
The machine is on none of it's limits and the GCode wouldn't exceed one of the limits.
When I reenable the machine and say "Run from here" and click on the same GCode line it does it without complaining, so it is very strange.
I also checked if the Swicth on the X axis is defective but it does not seem so.
Any ideas?
Best regards
hodor
BUT:
Any ideas?
Best regards
hodor
28 Jul 2013 20:43 #37162
by cncbasher
Replied by cncbasher on topic Randomly appearing "joint 0 on limit switch error"
are your limit switchs using screened cable ? , I would suspect your problem is noise on the limit switches , or perhaps look at using the debounce logic
- Mike_Eitel
- Thank you received: 185
29 Jul 2013 00:08 #37174
by Mike_Eitel
Replied by Mike_Eitel on topic Randomly appearing "joint 0 on limit switch error"
It's not a perfect solution...
But I use debounce for some msec.
Mike
Mike
The following user(s) said Thank You: Hodor
29 Jul 2013 19:57 #37215
As do I. I figure that being 5mS late in responding to a limit switch (which will almost certainly never be tripped) is a very minor problem.
www.linuxcnc.org/docs/html/man/man9/debounce.9.html
Replied by andypugh on topic Randomly appearing "joint 0 on limit switch error"
29 Jul 2013 23:03 #37232
by Hodor
Replied by Hodor on topic Randomly appearing "joint 0 on limit switch error"
Hi guys
I did not have time to try it yet, but i am very confident that you have solved my problem:) thank you
I will reply in this thread when it is completely solved.
thank you and good bye
Time to create page: 0.070 seconds
