+-10 volt spindle?
13 Sep 2013 08:01 - 13 Sep 2013 09:34 #38729
by DaOne
+-10 volt spindle? was created by DaOne
Well I thought my spindle drive was 0-10 with forward / reverse signals. I was gonna use the example to figure it out. Now it turns out that the drive has enable and 0- -10 = reverse and 0 - +10 = forward. So now I am at a loss on even where to start. Anyone have any examples? Would like it working as it should with M3/M4 commands and a S number. I have a mesa 5125 w 7i77. My spindle is 3450rpm at 10 volts. there is no brake and once enable is removed it brakes on its own.
Thanks,
Wes
Thanks,
Wes
Last edit: 13 Sep 2013 09:34 by DaOne. Reason: RPM was wrong
13 Sep 2013 08:48 #38731
Replied by PCW on topic +-10 volt spindle?
Is the +-10v control isolated (like a standard VFD) or is is hot (like a KBIC brush motor drive)?
If its isolated, you can use a 7I77 analog output to drive it (channel 5 because it has a separate enable)
13 Sep 2013 08:54 #38732
by DaOne
Replied by DaOne on topic +-10 volt spindle?
I dont quite understand but I would assume its isolated as I was able to make the drive work with a AA battery. If I switch the terminals around it spins the other way. The enable turns the drive on. Thats just a contact. (short them together the drive comes on)
Can you maybe give me an example on how to do it? Not the greatest with HAL as this is my first venture in LinuxCNC.
13 Sep 2013 09:16 #38734
That would probably work for either type but you might get shocked with
a non-isolated control!
What is the model number and manufacturer of the spindle controller?
13 Sep 2013 09:18 #38735
by DaOne
I will have to look. prob not the smartest but i held the wires to the battery with my fingers
![:) :)](/media/kunena/emoticons/smile.png)
13 Sep 2013 09:20 #38736
by DaOne
The drive is a Fuji FSD-15DN21
Its on a 1979 Hitachi Seiki 3NE-300
Here is all the info i have on it...
dl.dropboxusercontent.com/u/75606622/Hit...iring%20Diagrams.pdf
13 Sep 2013 09:28 #38737
by DaOne
13 Sep 2013 09:51 #38739
OK thats definitely isolated so you should be able to use a 7I77 analog output channel
(channel 5) to drive it and enable it
13 Sep 2013 09:53 #38740
by DaOne
PCW,
Any chance you could give me some example code to work with on this? The software end of this project has been a huge learning curve for me.
13 Sep 2013 10:09 #38741
Have you tried using pncconf? That might be a good starting point
Time to create page: 0.145 seconds
