Acceptable/helpful to debounce spindle tach?
- mtngun
30 Dec 2013 05:05 #42178
by mtngun
Acceptable/helpful to debounce spindle tach? was created by mtngun
As discussed on another thread, I'm struggling to get G76 threading to work satisfactorily on a lathe with a single spindle sensor (1 signal per rev).
Turning up the RPM helps quite a bit, so that the Z-speed "hunting" occurs perhaps 1 in 100 passes instead of 1 in 2 passes. The Z-speed "hunting" at higher RPM does seem to correlate to "blips" in the measured RPM.
However, even one bad threading pass would scrap the part, and it's an expensive part (gun barrels).
At PCW's suggestion, I've ordered the parts to replace my single sensor with an encoder. Hopefully that will help. But it may take a month or two for me to implement the encoder.
In the meantime, is it possible to filter out the occasional "blip" from my spindle sensor by using debounce? And if so, can someone please help me with the Hal (yes, I've searched, and am in the process of trying to modify my Hal, but I'm still too new to this to understand the half of it so I will probably need help to get it right).
- mtngun
30 Dec 2013 06:03 #42181
by mtngun
Replied by mtngun on topic Acceptable/helpful to debounce spindle tach?
To my amazement, I seem to have figured out the Hal code for debounce and it actually seems to work (modified Hal attached).
The relevant hal lines were:
loadrt debounce cfg=1
addf debounce.0 base-thread
setp debounce.0.delay 5
net spindle-phase-a-raw <= parport.0.pin-13-in-not => debounce.0.0.in
net spindle-phase-a <= debounce.0.0.out
So far the Z axis is behaving itself while threading, even at 68 rpm.
Anybody see anything wrong with my debounce setup, or anything that could be improved?
Does the delay=5 seem reasonable?
- mtngun
30 Dec 2013 06:57 #42183
by mtngun
- BigJohnT
- Thank you received: 1177
31 Dec 2013 07:24 #42210
by BigJohnT
Replied by BigJohnT on topic Acceptable/helpful to debounce spindle tach?
Nice!
JT
JT
Time to create page: 0.076 seconds
