Ferror and Min_Ferror
31 Dec 2013 01:14 #42202 by LAIR82
Ferror and Min_Ferror was created by LAIR82
Should these values be available to change in the calibration utility?
The Integrator manual says that they should, but it doesn't come up that way.
Rick
31 Dec 2013 07:22 - 31 Dec 2013 07:23 #42209 by BigJohnT
Replied by BigJohnT on topic Ferror and Min_Ferror
I do know if you don't have a variable in your ini the tune feature will not show it.
I don't know if ferror is one that is included or not.
Which section of the Integrator manual mentions that?
JT
Last edit: 31 Dec 2013 07:23 by BigJohnT.
31 Dec 2013 07:36 #42211 by LAIR82
Replied by LAIR82 on topic Ferror and Min_Ferror
In the INI section, under the description of Ferror.
I just noticed it today while I was tuning our third turning center. It would definitley make tuning a lot easier, I do have both of those variables in my INI sections and it dosen't come up.
Rick
31 Dec 2013 07:48 #42212 by BigJohnT
I agree the Integrators manual does hint that you can set something for ferror but it not very plain. I just checked etch servo and nothing shows up in the calibration about any ferror setting.
JT
02 Jan 2014 21:37 #42284 by LAIR82
IMHO, I think that all of the variables under each AXIS heading in the INI should be available in the Calibration Utility, that way you can tweak/tune without the need to shut down and restart to adjust certain things such as backlash, ferror and so on.
Rick
02 Jan 2014 22:14 #42287 by andypugh
Replied by andypugh on topic Ferror and Min_Ferror
The problem is that f-error is not a HAL pin (unlike the PID parameters for example) so the value can't be changed on-the-fly.
The motion controller reads the values from the INI file directly, and only at start-up.
In fact it is worth remembering that the entire INI file is only read once, at start-up. What the calibration utility does is change HAL values, then write the "good" values back to the INI for next time.
02 Jan 2014 22:34 #42288 by BigJohnT
I agree and now is the time to make a patch for master to do that.
JT
02 Jan 2014 23:04 #42290 by dgarrett
Replied by dgarrett on topic Ferror and Min_Ferror
there is a patch for master to make hal pins for several ini file items:
www.panix.com/~dgarrett/stuff/inihal.patch
the patch needs testers before it is added to master.
03 Jan 2014 00:15 #42292 by LAIR82
I am going to add this now to see how it works,
Thank You
03 Jan 2014 00:56 - 03 Jan 2014 00:58 #42295 by LAIR82
I added it, and the screen pops up with the added variables that can be adjusted.
Is it just a demo right now? How do change which axis you are adjusting?
Would this be integrated into the current Calibration Window?
I changed some numbers around, but did not see it reflected on my INI file.
Here is a pic for those that are interested.
Rick
Last edit: 03 Jan 2014 00:58 by LAIR82.
Time to create page: 0.109 seconds
